Re: Zinc in Marvel Mystry Oil ..
[Re: Stanton]
#688689
05/05/10 12:11 PM
05/05/10 12:11 PM
Posts: 9,316 SoCal
68HemiB
SoCal
Used as an oil additive in conservative amounts, it can quiet sticky, gummed up lifters and similar old-gunky-engineness.
Color me dubious when it comes to zinc content.
Personally, I use it as air tool oil.
Down to just a blue car now.
[Re: 68HemiB]
#688690
05/05/10 03:44 PM
05/05/10 03:44 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Silenced the lifters in my 318
The stuff rocks, my dad used it all the time.
[Re: 68HemiB]
#688694
05/05/10 05:38 PM
05/05/10 05:38 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I use it in my air tools. I love the wintergreen aroma
[Re: Scott Carl]
#688695
05/05/10 06:42 PM
05/05/10 06:42 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Local AutoZone doesn't carry it, so I used "Seafoam", same kinda stuff, great results in freeing up stuck lifters.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
[Re: dynamite]
#688696
05/12/10 07:49 AM
05/12/10 07:49 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
This is copied from another thread. We analyzed and tested both of these additives at Exxon. Marvel Mystery oil is 30% varsol (charcoal lighter fluid) and 70% 30wt base oil some red dye and wintergreen fragrance. It is from the late 1920s. Avblend is very light weight paraffinic base oil (sewing machine oil)with 1% ether and blue dye. It is from the late 1950s. If it is absorbed by the metal, why doesn't it leak out of the can? These are solvent type products. Some people find them beneficial for sticky valves or some sludge dispersal. If you are depending on them for either of these reasons, you have bigger problems. Both evaporate within hours in an engine. Neither one provides any corrosion protection or anti-wear benefit. Neither one will harm anything in the recommended concentration. Regards, Ed Edward Kollin Techncal Director Aircraft Specialties Lubricants www.aslcamguard.com
[Re: Hoof Hearted]
#688699
05/12/10 06:27 PM
05/12/10 06:27 PM
Posts: 905 SD
zrxkawboy
SD
70% Light Aromatic Oil (Pale Oil) - It is a Naphthenic Oil, so while it oxidizes faster than a Paraffinic oil, it does clean and dissolve sludge and carbon well and cleans up after itself from any oxidation. serves as base oil as well. [Naphthenic oils have more solvency and are more polar (they are attracted to metal more), but oxidize faster. 29% Mineral Spirits - Cleans Varnish very well. General cleaner. Also acts as an antioxidant. 38 parts per million (ppm) Boron - AW/EP agent, friction reducer, antioxidant 900 ppm Phosporous - AW/EP agent 1/2% 1, 2 ortho-Dichlorobenzene - EP agent as it interacts with Iron to form an Iron chloride barrier under any ZDDP or other AW additives. Also very good cleaner/solvent, and friction reducer 1/4% 1, 4 para-Dichlorobenzene - EP agent as it interacts with Iron to form an Iron chloride barrier under any ZDDP or other AW additives. Also very good cleaner/solvent, and friction reducer Oil of wintergreen - for the scent - Not just for the cent, is also a cleaner. may aid lubricity. Red Dye - for the color - well this one just colors the stuff http://www.bobistheoilguy.com/forums/ubb...;gonew=1#UNREAD
It's Swifty! Swifty, you toad sucker!
[Re: cornucopia]
#688701
05/12/10 11:07 PM
05/12/10 11:07 PM
Posts: 9,150 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
we use it to shine up the interior of Wilbert burial vaults prior to the funeral service.
What is a "Wilbert" burial vault?
[Re: Commando1]
#688703
05/14/10 12:31 AM
05/14/10 12:31 AM
Ramrod39
My New Title
My New Title
Tucson, AZ
Oh. It's a T-shirt. Thanks!
