Octane boost/fuel additives? #687758
05/03/10 09:53 PM
05/03/10 09:53 PM
S.I. N.Y.
1MYTGTX Offline OP
1MYTGTX  Offline OP
S.I. N.Y.
Any one recommend any good octane boosters? One that has valve seat protection capabilities as well?
I was running BND Automotive's ACESIV stuff for a while & was wondering if there was anything comparable?
1MYTGTX
Re: Octane boost/fuel additives? [Re: 1MYTGTX] #687759
05/03/10 10:03 PM
05/03/10 10:03 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
all i know is that bnd stuff doesnt work.
Re: Octane boost/fuel additives? [Re: 05dakota] #687760
05/04/10 03:36 AM
05/04/10 03:36 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Has anyone tried that REAL LEAD stuff advertised in Mopar Collectors Guide? It seems that if it were real, the EPA would be all over them.
Re: Octane boost/fuel additives? [Re: 1MYTGTX] #687761
05/04/10 08:11 AM
05/04/10 08:11 AM
pgh pa
captaindodge Offline
pgh pa
I top off my tank of 93 octane with about 2 1/2 gallons of E-85 because it is said to be approximately 105 octane. This will not help the valve seats but it allows me to add some extra ignition advance.
Re: Octane boost/fuel additives? [Re: captaindodge] #687762
05/04/10 08:35 AM
05/04/10 08:35 AM
S.I. N.Y.
1MYTGTX Offline OP
1MYTGTX  Offline OP
S.I. N.Y.
Any others??
1MYTGTX
Re: Octane boost/fuel additives? [Re: captaindodge] #687763
05/04/10 08:54 AM
05/04/10 08:54 AM
(Central) PA
Runner2go Offline
Runner2go  Offline
(Central) PA
Y probably you probably don't want a mixture with Gas/E85 in over the winter.
Bad things happen with gas/ethanol and winter storage... take it from millions of boaters every where.
This helps some... but not a guarantee the gas won't deteriorate and gum up the carb
Sta-Bil Marine...for gas with Ethanol
Marine Formula Sta-Bil
New, concentrated formula designed to fight the damaging effects of Ethanol
1966 383, 4-sp Charger 38yrs
1970 440+6, 4-sp Road Runner 36yrs
1974 360, auto Challenger 25yrs,in Family 41yrs
2003 Ram 2500 QCLB 4x4 Cummins HO
2010 5.7L R/T 6sp Challenger - Mopar10
2018 392 Daytona Charger
Re: Octane boost/fuel additives? [Re: Runner2go] #687764
05/04/10 11:22 AM
05/04/10 11:22 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i use TORCO 16410 Unleaded Accelerator Octane Booster , but doesnt offer valve seat protection.
Re: Octane boost/fuel additives? [Re: 1MYTGTX] #687765
05/04/10 01:44 PM
05/04/10 01:44 PM
NL
Frederick Offline
Frederick  Offline
NL
I use Castrol valvemaster plus.
But don't know if you can get it in the states.
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
Re: Octane boost/fuel additives? [Re: Frederick] #687766
05/04/10 02:14 PM
05/04/10 02:14 PM
S.I. N.Y.
1MYTGTX Offline OP
1MYTGTX  Offline OP
S.I. N.Y.
Looks interesting.... not sure if I can get it shipped here...
Castrol Valvemaster
Should you not wish to have your car classic car engine converted to consume lead-free petrol by means of cylinder head conversion etc, then you are highly advised to use a petrol additive. The lead in petrol plays two major roles; firstly it prevents valve recession into the head by means of lubricating action, and secondly provides an octane boost to ensure correct burning and alleviate pre-ignition (reducing pinking). Either of Castrol's products are designed to replacement the lead element missing in unleaded petrol. The Valvemaster Plus also contains an octane booster to boost the octane level of unleaded petrol up to the desired 98 level (equivilent of the old 4 star) for correct running of classic cars. Should you not wish to use the octane booster then we would advise you to either alter the engine timing to account for the lower octane rating of unleaded petrol or use the more expensive super-unleaded.
With obvious concerns about the efficacy of Lead Replacement Petrol (LRP), especially as regards its lack of a British Standard, and the petrol companies' own warnings regarding the unsuitability of their product for "everyday" use, most owners are opting to use Castrol's Valvemaster plus.
1MYTGTX
Re: Octane boost/fuel additives? [Re: 1MYTGTX] #687767
05/04/10 03:12 PM
05/04/10 03:12 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
