Re: Who has used VHT high temp paint on headers
[Re: Stanton]
#687559
05/03/10 10:19 PM
05/03/10 10:19 PM
DaytonaTurbo
Manitoba, Canada
Needs sandblasting to prep. Goes on like water. Scratches easily till its cured. Doesn't last.
Mine started rusting through the vht paint within a month of use. Will try something else next time.
[Re: Stanton]
#687560
05/03/10 10:31 PM
05/03/10 10:31 PM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
I agree for the most part. The headers on my wife's Barracuda looked good for 3 years using VHT ceramic black paint. With that said, it's just a fair weather cruiser. If we drove it every day, the paint would have gone south much faster.
I had the headers ceramic coated black by a local company over the winter. We'll see how they last this time around.
[Re: 75dusted]
#687563
05/04/10 12:17 AM
05/04/10 12:17 AM
Posts: 41 New Jersey
Alan
New Jersey
For success, one must: 1) Sandblast - and wear rubber gloves so your skin oil does not contaminate the clean metal 2) Wipe down w/ acetone - to get and grease or oil out if there... 3)Spray two coats VHT - more will cause blistering. 4) Ona cookie sheet, "bake" your painted headers up to 450 degrees temp in you kitchen oven ( hint: make sure wife is gone for the day). 5) bolt up and enjoy.
- Alan
Moderator Emeritus
~ Soon to unveil the world's only '69 Road Runner 440 R/T...
"A fantasy car that never existed, but could have."
[Re: Kern Dog]
#687565
05/04/10 09:03 AM
05/04/10 09:03 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Ya, like who has an oven that big ?!?!?!?
[Re: Stanton]
#687566
05/04/10 11:10 AM
05/04/10 11:10 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
He must have small ones!
[Re: HitIt]
#687568
05/04/10 01:02 PM
05/04/10 01:02 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Instead of VHT, I used Eastwood's High Temperature Exhaust paint. I first glass-bead blasted my manifold, then (wearing rubber gloves) washed it with hot soapy water, rinsed and blew it dry with compressed air. I applied a liberal coating of Eastwood's PRE paint prep, then sprayed a couple coats of the High Temp paint on. I've put over 1,000 miles on it since January 2009, and haven't noticed any flaking or rusting.
[Re: Fab64]
#687569
05/04/10 03:35 PM
05/04/10 03:35 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I used it on manifolds and found it worked well. Headers...not a chance. They are a totally different ball game. Even powder coating will come off if you have a problem with timing etc.. As mentioned, don't waste your time
[Re: dave571]
#687570
05/04/10 03:57 PM
05/04/10 03:57 PM
Posts: 1,015 Howell, Michigan
Hemidavey
Howell, Michigan
I've used VHT on headers it lasted 2 years then started going bad slowly. Acetone wash and sand blast prep is a must. If you touch them with your bare hands before or after paint you will see it soon! I gave up on ceramic coatings, my new Jet Hot headers rusted and so did another fellows, not sure where he went. Mine are pealing badly on my Dart. Jet Hot did em twice! The only thing that I find that works every time is stainless steel. Its only too expensive if your selling the car. I've had my Cuda for 27 years, never using mild steel again. Ad up the value of your time , blasting, paint, prep year after year?
