68 B body master cly question #687529
05/03/10 06:31 PM
05/03/10 06:31 PM
dark side of the moon
Dougsmopars Offline OP
Is it a different master for power brakes.? Car is drum all around. Got a new, not reman master from Rabestos and it says for both manuel or power. Just checking to see if power master is different then manuel.
Re: 68 B body master cly question [Re: Dougsmopars] #687530
05/03/10 07:11 PM
05/03/10 07:11 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Doug...'68 parts book says p.n. 2808599 fits all drum brake vehicles power and manual.
Re: 68 B body master cly question [Re: superwrench] #687531
05/03/10 07:15 PM
05/03/10 07:15 PM
Thanks. Just wanted to make sure before i put this one in.
Re: 68 B body master cly question [Re: Dougsmopars] #687532
05/04/10 01:36 AM
05/04/10 01:36 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
your should look diferent than this one off my power disc 68
Re: 68 B body master cly question [Re: Dougsmopars] #687533
05/04/10 09:10 AM
05/04/10 09:10 AM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
67-70 power or manual drum uses the same master cylinder.
Re: 68 B body master cly question [Re: ademon] #687534
05/04/10 04:50 PM
05/04/10 04:50 PM
Actually that is what it looks like. paper work said power or manuel drum. It's a new master from Rabestos. But does have lines on the other side towards the inner fender.
Re: 68 B body master cly question [Re: Dougsmopars] #687535
05/04/10 05:35 PM
05/04/10 05:35 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
power or manual, makes no difference
drum brakes only
