Priming oil pump on 440, which way clockwise or counter #686388
05/02/10 10:31 AM
05/02/10 10:31 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I'm getting ready to prime my 512 for start and wanted to know whichway to spin the drill for priming the oil system? CLockwise or counterclockwise?
Re: Priming oil pump on 440, which way clockwise or counter [Re: NV69B7RR] #686389
05/02/10 10:35 AM
05/02/10 10:35 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Counter Clockwise
Re: Priming oil pump on 440, which way clockwise or counter [Re: topside] #686390
05/02/10 10:44 AM
05/02/10 10:44 AM
OT but here is an interesting (5 minute) read on ring seal during breakin that may benefit you. "break in secrets" at www.mototuneusa.com
Re: Priming oil pump on 440, which way clockwise or counter [Re: RapidRobert] #686391
05/02/10 10:49 AM
05/02/10 10:49 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks! I've got the Makita ready to go. I htough it was counterclockwise, but just wanted to be sure.
Re: Priming oil pump on 440, which way clockwise or counter [Re: NV69B7RR] #686392
05/02/10 11:12 AM
05/02/10 11:12 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Have a friend slowly rotate the crankshaft as you prime.
Ride eternal, shiny and chrome
Re: Priming oil pump on 440, which way clockwise or counter [Re: DirectSubjection] #686393
05/02/10 11:16 AM
05/02/10 11:16 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Will do. I'm only getting oil on the pass side rockers, so I'll be pulling the dr side rockers loose shortly.
Re: Priming oil pump on 440, which way clockwise or counter [Re: DirectSubjection] #686394
05/02/10 11:17 AM
05/02/10 11:17 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
....and BE SURE to use a rod that has some protection on it ....so the hex-shape will not damage the bushing.
HENCE .. the reason why I am having some of the hex-rods PVC coated so there is no worries there.
Re: Priming oil pump on 440, which way clockwise or counter [Re: NV69B7RR] #686395
05/02/10 11:21 AM
05/02/10 11:21 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
What is the reason to loosen drivers side rockers?
Re: Priming oil pump on 440, which way clockwise or cou [Re: NV69B7RR] #686396
05/02/10 11:24 AM
05/02/10 11:24 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
no need to pull the rockers, they get a "pulsed" oil supply as the engine rotates through the #4 cam bearing. that's why you want someone to rotate the crank as you prime.
Re: Priming oil pump on 440, which way clockwise or cou [Re: dirtybee] #686397
05/02/10 11:34 AM
05/02/10 11:34 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
If you have a priming rod that is prepped to protect from harming the bushing ...ALL you have to do is lay the drill up against the motor ...and you can bar-over the motor yourself.
