The best I can describe it to you is it's just noisy, at all RPM's from what I can tell anyway. Motor had a recent rebuild, resused valvetrain components though except cam and lifters, re-ring, new gaskets etc. Just a totally budget rebuild. I know it has a little piston slap from being honed and reusing the stock pistons and reringing. But that goes away after it gets warm, plus I plan on a 440 swap on down the road.
It ptobably has 200 miles on it. I never knew there was a specific position to those shafts. Thought it was just a bolt on and go. Thanks for the info.
