Motor mount and oil pan questions
#685417
05/01/10 02:19 PM
05/01/10 02:19 PM
Posts: 659 Boise Idaho
Boise Chall
Boise Idaho
I am working on a 73 Satellite originally a 318/904 car. I am putting a 78 motorhome 440/727 in it. Do I need to buy the shumaker motor mounts for it or can I just use these complete mounts from autozone http://www.autozone.com/autozone/catalog...ext=motor+mountalso the oil pan I have is a 187 do I need the 971 pan or will this pan work. I know I need to change the tranny tail shaft but I'm not to that point yet
Re: Motor mount and oil pan questions
[Re: Viol8r]
#685421
05/01/10 04:46 PM
05/01/10 04:46 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
All I can say is if they are the Poly Schumacher mounts, they will feel very close to solid. I personally had them in for one day.
Mancini Racing has a Magnum mount which I recommend.
I had both Schumachers in for about an hour. Then replaced the passenger side with stock. 80-90% of the vibration went away and the benefit of the mount remains. Thats the way to go. Notice that they won't sell them in singles though!
[Re: Boise Chall]
#685424
05/01/10 10:25 PM
05/01/10 10:25 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I just bought mounts for my '71 charger (different mount) You will need the big block brackets and the mounts on the Auto Zone site look like what you need. My preferance is a rubber mount if it's a street car. Oil pan, I think any center sump should work. I bought a 933 and a stock pick up for mine. Motor and trans was out of a Dodge 300 Van Ambulance.
