tips on starting a flooded car? *DELETED* #685315
05/01/10 11:12 AM
05/01/10 11:12 AM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Post deleted by AHall
Re: tips on starting a flooded car? [Re: AHall] #685316
05/01/10 11:15 AM
05/01/10 11:15 AM
block the choke open/hold it to the floor and I use a shot of starting fluid for these rare occaisions
Re: tips on starting a flooded car? [Re: RapidRobert] #685317
05/01/10 11:16 AM
05/01/10 11:16 AM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
what if I dont have starting fluid? Could trying the other two you said work?
Re: tips on starting a flooded car? [Re: AHall] #685318
05/01/10 11:17 AM
05/01/10 11:17 AM
Kirkland, Washington
Pacnorthcuda Offline
you might want to check for spark.
Re: tips on starting a flooded car? [Re: AHall] #685319
05/01/10 11:23 AM
05/01/10 11:23 AM
yes & if no go might pull 1 plug real quick to see if you need to pull/dry them. only push the pedal to the floor once as the AP shot is going to aggravate this and on an eddy I take off the AP link as it's easy to do
Re: tips on starting a flooded car? [Re: Pacnorthcuda] #685320
05/01/10 11:28 AM
05/01/10 11:28 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
You dont say how it got flooded, make sure the floats aren't stuck adding more fuel to the problem as your cranking. Holleys are easy to check, pull the sight plug and if a lot of fuel runs out the float may need to be adjusted. Remember everytime you step on the accelerator you are adding 30cc or more of raw gas to the intake because of the accelerator pump. Is the choke the bimetal spring type? Lock it open before you even start. Hold the accelerator down and dont pump it. Starter fluid might help, but I've seen more than one carburator fire from trying to start a really flooded engine using that so be ready for that possibility. let it set for a while if you can and some of the gas will naturally evaporate out of the system. Like someone said earlier if you dont have a spark it wont run. If all elae fails pull the plugs, spin the engine to clear the cylinders and then try it.
Re: tips on starting a flooded car? [Re: Cudajon] #685321
05/01/10 01:00 PM
05/01/10 01:00 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Holleys pump 30cc in 10 strokes.
Re: tips on starting a flooded car? [Re: RemCharger] #685322
05/01/10 01:38 PM
05/01/10 01:38 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Simply amazing the things you learn.
Holley accelerator pumps.
Now I will grant none of em ever deliver what they advertise.
Re: tips on starting a flooded car? [Re: Cudajon] #685323
05/01/10 01:43 PM
05/01/10 01:43 PM
PA
U
unclemike Offline
unclemike  Offline
U
PA
Stay away from starting fluid, I had that stuff blow a plug out of an aluminum 4 cyl. head.
Pull all the plugs and let it set until the gas build up evaporates out of the cylinders.
Do the other checks for float level and spark.
BTW If you are running a Holly check for a ruptured power valve.
Re: tips on starting a flooded car? [Re: Cudajon] #685324
05/01/10 07:07 PM
05/01/10 07:07 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
If you are going to do this, make sure you pull the coil wire out of the coil before you start to spin the engine. You'll have gas fumes going everywhere DAMHIK!!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: tips on starting a flooded car? [Re: Pacnorthcuda] #685325
05/01/10 10:10 PM
05/01/10 10:10 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
yea, got that!
Weird, I give it more than one squirt and it floods on me. Had to wait 30 mins and after a couple of cranks it fired up.
Re: tips on starting a flooded car? [Re: AHall] #685326
05/01/10 10:49 PM
05/01/10 10:49 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
install fresh plugs....once they are soaked...they don't work that good...
Re: tips on starting a flooded car? [Re: AHall] #685327
05/01/10 11:08 PM
05/01/10 11:08 PM
Daisyland USA
jnkgal Offline
jnkgal  Offline
Daisyland USA
around these parts today you just push it off to the side.
we got two interstates shut down in both directions secondary roads shut down
8-12 inches rain they say 6-8 more and severe thunderstorms.
place looks like an island
wont be able to go to school for a week and next week were my finals.
houses floating down the road
people were stranded on train
rescuing people out of their cars in boats off the interstate
if it were a week day and rush hour I can not imagine semis sitting everywhere flooded up to windows or higher buses water over the top in areas. have to from now on carry a life perserver and blow up raft in my truck just in case lol
guess will take a canoe tomorrow if I have to go anywhere lol
"A goal without a plan is just a wish."
Re: tips on starting a flooded car? [Re: AARCONV] #685328
05/02/10 12:29 PM
05/02/10 12:29 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
What plugs would you install? (mild 440 with Stealth aluminum heads)
Re: tips on starting a flooded car? [Re: AHall] #685329
05/02/10 12:31 PM
05/02/10 12:31 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Champion RC12YC
Re: tips on starting a flooded car? [Re: ireland383] #685330
05/02/10 12:49 PM
05/02/10 12:49 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Champion RC12YC
Thanks. I was just digging around in the garage and came across 8 NGK XR51X iridium plugs- should I try those or just go buy 8 of those champions? Currently there are Autolite plugs in there. (previous owner installed those)
What gapping should these plugs be gapped at?
Re: tips on starting a flooded car? [Re: AHall] #685331
05/02/10 01:07 PM
05/02/10 01:07 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Champion RC12YC
.035 gap, I had Autolite 3924's before. The car liked the champs better. I'm not sure if those NGK's are compatible. The champs are fairly cheap 1.99 each at Napa.
Re: tips on starting a flooded car? [Re: ireland383] #685332
05/02/10 02:16 PM
05/02/10 02:16 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Ok, just pulled the plug and glad I checked em vs the NGK- NGK is much shorter.
Here is a pic of the spark plug I pulled and the 2nd pic is the Autolite vs the NGK (NGK much shorter)
Re: tips on starting a flooded car? [Re: AHall] #685333
05/02/10 03:19 PM
05/02/10 03:19 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Yeah you need the longer reach. Those plugs don't look bad.
Re: tips on starting a flooded car? [Re: ireland383] #685334
05/02/10 04:26 PM
05/02/10 04:26 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
went ahead and put the champions in thanks for the recommendation!
Re: tips on starting a flooded car? [Re: AHall] #685335
05/03/10 11:38 AM
05/03/10 11:38 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
that ngk plug is not the correct application.
