One last Converter Question?? #684840
04/30/10 05:26 PM
04/30/10 05:26 PM
USA
Suregrip391 Offline OP
USA
When buying a torque converter for a 400 Chrysler (that came out of god only knows)....Im being asked the following questions and I have no idea? Do I need a neutral balance converter or a weighted version for external balance / cast crank applications ?? Any way I can find this out prior to disassembly what I will need to order?
Re: One last Converter Question?? [Re: Suregrip391] #684841
04/30/10 05:32 PM
04/30/10 05:32 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Your 400 has a cast crank, you will need the weighted / external balance converter.
Re: One last Converter Question?? [Re: DaytonaTurbo] #684842
04/30/10 06:49 PM
04/30/10 06:49 PM
USA
USA
Thank you! Also need to know if they would be 3/8 or 7/16 torque converter bolts. Are all the 400's the same?
Re: One last Converter Question?? [Re: Suregrip391] #684843
04/30/10 07:04 PM
04/30/10 07:04 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I doubt if ANY 400 engines came with the larger bolts, since they were primarily a medium performance smog era motor. If you somehow get the converter with the larger bolt size, you can drill your flexplate holes oversize.
Re: One last Converter Question?? [Re: Suregrip391] #684844
05/01/10 05:45 PM
05/01/10 05:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All factory converters except the 426 Hemi came with 5/16" bolts.
