Re: 318 Carb Recommendation
[Re: warpspeed]
#683594
04/29/10 02:42 PM
04/29/10 02:42 PM
Posts: 15,487 Florida
scratchnfotraction
I run a 600 eddy carb on a 88- 360 headed 318 roller cam engine with an LD4B intake lunati voodoo roller cam 60710-comp 901-16 springs,stock roller lifters and valve gear 258/264 207/213 .485/.485 works great,set it and forget it till its dirty never been one to tune on holley gas holes the universal holley 600 works great for the swap to a 4-v on a a sb driver I also by pass the BR and run a points dist with a pertronix points conversion kit with flame thrower coil..I give it a full 12V with the ecu unpluged and BR bypassed never used the elect mopar stuff and ecu myself
[Re: warpspeed]
#683595
04/29/10 03:42 PM
04/29/10 03:42 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
Hey In the past I havent been a big Edelbrock fan, but I put an Edelbrock Performer 600 on the stock (eddy LD4B intake & electronic ignition) 318 in my '67 Coronet and it ran absolutely flawlessly all last summer. It got better gas mileage than the stock 2-bbl did too.
Paul '69 Super Bee 383 EFI Turbo
[Re: RapidRobert]
#683603
05/03/10 05:11 PM
05/03/10 05:11 PM
Posts: 101 South Carolina
warpspeed
South Carolina
Well, guys, I was at wits end last week working on starting this engine. It is in an 1985 Dipomat. As far as I could tell, there was nothing done to this engine during its 70K orginal miles. I bought a new Eddy 600 at the local auto parts store and bolted it on. I have been through everything that I know about setting the engine up to be sure that it would run, not just start. Well, to make a long story short, I finally blew my top and starting turning the distributor, CCW, until it started and ran like a top. The whole system is 90 degrees off from where it should be. I beleive that the lean burn system on the engine was set 90 off to accomodate something in their system. There is a debate running concerning this at the dippy site, but the truth is; the engine is running great with the 600 carb. In fact my neighbor who I bought the car from told me that the car sounded better and quieter than he ever knew it. Of course I replaced the plug wires, cap etc. The 600 is working great!!!!
[Re: RapidRobert]
#683605
05/04/10 07:58 AM
05/04/10 07:58 AM
scratchnfotraction
you can run a flat tappet cam in a roller block with corret lifters and push rods my roller block had a slider an I swaped up to a roller and stock roller lifters and push rods pul the dist and turn it 180* and drop it back in it either on or 180* out and can be wired to run that way some times the vac can hits stuff so you would turn it 180* to gain more room to adjust it
