Idle is better with exhaust corked #68291
06/05/08 10:57 PM
06/05/08 10:57 PM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
If you get a better idle quality with the exhaust corked, vs. open, does that mean that open exhaust richens the mixture?
Just wondering.
"Im supercharged, might explode in your face"
Re: Idle is better with exhaust corked [Re: Verga] #68292
06/05/08 11:05 PM
06/05/08 11:05 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Just wondering.
If anything the open exhaust leans your fuel/air mixture. How do you define better? Are you sure it isn't just because you have more unwanted sound? -Bob
Re: Idle is better with exhaust corked [Re: BobR] #68293
06/06/08 08:53 AM
06/06/08 08:53 AM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
I have always heard that open exhaust leans your mixure also. The cars idles much smoother with the exhaust corked, especially in gear.
Re: Idle is better with exhaust corked [Re: Verga] #68294
06/06/08 09:00 AM
06/06/08 09:00 AM
i think the answer is obvious.. don't you? in case you don't..
open exhaust requires a different tune then a closed exhaust.
Re: Idle is better with exhaust corked [Re: Verga] #68295
06/06/08 09:02 AM
06/06/08 09:02 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I read somewhere that high exhaust backpressures actually lean out the mixture because at idle when there is valve overlap some of the exhaust backs up into the cylinder and dilutes the incoming mixture. So in theory open headers will make the engine run richer at idle.
Re: Idle is better with exhaust corked [Re: dmerc] #68296
06/06/08 09:37 AM
06/06/08 09:37 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
You have it backwards. The exhaust back pressure would richen the mixture.
Re: Idle is better with exhaust corked #68297
06/07/08 10:51 AM
06/07/08 10:51 AM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
I think its obvious you are an A!!H!le. Dont you? in case you dont, you are one!!!
Re: Idle is better with exhaust corked [Re: Verga] #68298
06/07/08 10:53 AM
06/07/08 10:53 AM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
It seemed odd to me that the idle was better corked than open, cuz I still dont have the carb dialed in 100 percent at idle. Ive got to start opening the holes in the blades, cuz too much of the transer slots are showing already. I figured with the exhaust open it would raise the idle RPM slightly, but it did the opposite.
Re: Idle is better with exhaust corked [Re: Verga] #68299
06/07/08 12:01 PM
06/07/08 12:01 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
If you have to open the blades past the transfer slots then you are dead rich and the open headers are bandaiding the problem. I have always remedied that situation by drilling holes in the blades. Start small-say a 3/32 drill and open as needed. Drill all 4 blades and chamfer the holes. Other methods include leaning the idle bleeds ect but the drill method has always worked for me. BTW this is exactly what the Holley book will tell you to do. -Bob
Re: Idle is better with exhaust corked [Re: BobR] #68300
06/07/08 12:05 PM
06/07/08 12:05 PM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
[quote
Yes, I agree Bob, but it idles better corked, not open. Which to me is backwards. If uncorked leans it out, Id think it would idle better open.
Re: Idle is better with exhaust corked [Re: BobR] #68301
06/07/08 02:03 PM
06/07/08 02:03 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
yes the books will say drilling is an option.
you really shouldnt half to unless this is some monster of a brute.
Re: Idle is better with exhaust corked [Re: Verga] #68302
06/07/08 02:17 PM
06/07/08 02:17 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Uncorking headers leans out the mixture due to a non-restricted flow.
Your engine is able to move more air uncorked. You need to fatten up the mixture to compensate for the increased air flow.
Reading your spark plugs corked vs. uncorked will tell you that.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Idle is better with exhaust corked [Re: 340727dart] #68303
06/07/08 02:52 PM
06/07/08 02:52 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
open the idle screws an 1/8 turn.
Re: Idle is better with exhaust corked [Re: VanishPt] #68304
06/07/08 03:32 PM
06/07/08 03:32 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
If he is truly into the transfer slots the idle mixture screws won't do much, in anything. I agree with pulling and reading your plugs. Idling with the transfer circuit will give you dark and maybe wet plugs. -Bob
Re: Idle is better with exhaust corked [Re: Verga] #68305
06/07/08 03:44 PM
06/07/08 03:44 PM
