O-ring t-stat housing? #682422
04/27/10 11:35 PM
04/27/10 11:35 PM
Milwaukee, WI
Prince_Valiant Offline OP
Milwaukee, WI
I can run the summit T-stat housing for a chevy on my small block eddy intake, correct?
tia,
chris
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: O-ring t-stat housing? [Re: Prince_Valiant] #682423
04/27/10 11:45 PM
04/27/10 11:45 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
yes as long as you don't use a thermostat. the chevy thermostat will fall through the hole in the intake.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: O-ring t-stat housing? [Re: Jerry] #682424
04/28/10 12:31 PM
04/28/10 12:31 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
and dont care about it leaking
Re: O-ring t-stat housing? [Re: Prince_Valiant] #682425
04/28/10 01:13 PM
04/28/10 01:13 PM
Milwaukee, WI
Milwaukee, WI
Point is moot anyways...found a mopar correct unit:
http://www.summitracing.com/parts/BSP-90820/
as to the leaking part, I've never had bad luck with o-rings...they've actually worked better than the gasket and gasket/gobs of rtv I've used in the past.
thanks guys
