temp gauge sensor
#682329
04/27/10 11:19 PM
04/27/10 11:19 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i have 68'b body with 440, non ralley dash, i am wanting to keep the factory temp gauge working in the cluster and i am putting aftermarket temp guage under the dash, my question is, i do not have 2 outlets on my water pump for another sensor i wld have to take off the pump and drill another sensor hole, i want to hook the factory gauge and the new temp gauge on the same sensor, i have not been able to crank the car to test it yet, putting new dist. in, i was wondering if anybody is doing this? will it work?
Re: temp gauge sensor
[Re: cornet684me]
#682330
04/27/10 11:24 PM
04/27/10 11:24 PM
Posts: 10,132 A Red State
SNK-EYZ
A Red State
Isn't there a hole for a sensor behind the alternator bracket? It might be tough to see. There's usually one there as well as on top.
[Re: SNK-EYZ]
#682331
04/27/10 11:28 PM
04/27/10 11:28 PM
cornet684me
Brandon, Ms
not on this set up, i have pieced together a 73motor home 440 and i an early water pump housing, earlier 60's i think, there is only 1 sensor hole on this water pump, i have all but taken the water pump off, , i was hoping that the 1 sensor wld run both the factory guage and the new aftermarket guage, the aftermarket guage does have the same sensor, however i do not know what is going to happen when you run 2 gauges off the same sensor?
