Re: Another speedo pinion situation
[Re: Kern Dog]
#681445
04/27/10 11:12 AM
04/27/10 11:12 AM
RapidRobert
I put a piece of flat stock on top of a rear tire and measured underneath it to ground for my EXACT dia which might be slightly different from the tire mfr's listed dia and if your're in the middle could nudge you up or down to the correct whole number. W that figure and the gear ratio the simple chart in the archives worked dead on for me and made my odo be correct measured at the mile markers on the interstate. passed each one in exactly 60 seconds at 60 mph THEN at a road sign digital MPH sign my speedo was also correct which the odo can be correct (& the correct pinion will gaurantee that) but the magnetic speedo gismo can still be off (& the speedo head needs to come out and take n to a specialy speedo shop) but the correct pinion as you know needs to be selected 1st. BUT I was chastized (on here!) for not using rollout to get an absolute figure since under load the tire is not a perfect circle which will then take more math as opposed to just using the dia on the chart.
