Piston help #681024
04/26/10 07:15 PM
04/26/10 07:15 PM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
Ok guys I am looking for some 400 big block pistons. I am searchin for stock stroke , dish ,forged with the .990 size pin. Any ideas? I scored a great deal on a stock stroke eagle crank and a set of 6.385 eagle h beam rods and i want to stick some pistons together for a low compression turbo motor.
I need like 8.5 or 9 to 1 with 75cc heads.
www.sikosracing.net Heads up Drag racing
Re: Piston help [Re: moparmattkos] #681025
04/26/10 07:58 PM
04/26/10 07:58 PM
Illinois
mopar addict
mopar addict
Illinois
I found these pistons and the add says stock stroke 400 but it also says 3.75 stroke.???
It also doesnt mention rod length???
http://www.hughesengines.com/Index/produ...mp;partid=23785
Re: Piston help [Re: moparmattkos] #681026
04/26/10 08:37 PM
04/26/10 08:37 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Check the compression distance. The Diamond piston you linked to has a 1.32" CD, This would be for the 3.75" stroke 6.768" rod engine.
FWIW, those pistons in a stock stroke / rod 400 with would have the piston sitting 0.612" below the deck, and with 84 cc heads new a whole 4.24:1 compression ratio.
Depending on the head volume you are using, stock flat top 400 pistons are already a low compression design.
The stock replacement flat tops have a compression height of 1.812" and the piston sits 0.120" below the deck at TDC. with 84 cc heads and 0.040" head gasket the compression ratio is 7.75:1.
For the stock stroke/rod combination there is not much of a selection of off the shelf pistons. For what you are doing, you will likely need to order custom pistons.
Re: Piston help [Re: 451Mopar] #681027
04/27/10 08:37 AM
04/27/10 08:37 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You best bet would be to go to diamond pistons and have a custom piston made they are real reasonable about the same price as their good forged shelf pistons
http://www.diamondracing.net/
Re: Piston help [Re: 451Mopar] #681028
04/27/10 05:55 PM
04/27/10 05:55 PM
Illinois
mopar addict
mopar addict
Illinois
I have 72cc indy big ez's full cnc heads and i need low compression forged pistons for a turbo appication. I would ideally like to have 8.5 to 1
Re: Piston help [Re: moparmattkos] #681029
04/27/10 06:06 PM
04/27/10 06:06 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
The pistons would prob have to be custom but do you realize how much those pistons would weigh and how tall of a compression height they would be, and then put them boat anchor pistons under a nice set of big ez's not a good idea in my opinion. I would sell your rods and find you some 440 length rods with a .990 pin and use the pistons you posted up top.
One day I will have something cool here.
Re: Piston help [Re: sdaurity] #681030
04/27/10 06:09 PM
04/27/10 06:09 PM
Illinois
mopar addict
mopar addict
Illinois
The pistons up top are 10.5 to 1 at 72cc i need 8 to 8.5 to 1 compression.
Re: Piston help [Re: moparmattkos] #681031
04/28/10 08:08 AM
04/28/10 08:08 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
well you need to call your favorite piston company and place a custom order.
