Lockup style tranny interchange #680091
04/25/10 07:06 PM
04/25/10 07:06 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Have the opportunity to purchase a 72 Dodge B100 Van with a slant 6,for next to nothing because it needs a tranny(Automatic).
I can also score an entire 1980 D100 Longbed with a bad slant 6 engine but good Torqueflite tranny for dirt cheap.
Is the tranny in the 1980 truck a lockup style?
Will the truck tranny bolt right up to the 1972 slant 6 thats in the van,or are there tailshaft issues to also consider?
Re: Lockup style tranny interchange [Re: SPWC] #680092
04/25/10 08:47 PM
04/25/10 08:47 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
It should bolt right up. Look underneith and if the van has a 1 piece shaft & both have a slip yolk in front you should be home free.
