Re: 440 sounds clattery [Re: HitIt] #679943
04/26/10 01:10 PM
04/26/10 01:10 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I’ve done some research here, seems like they should have a bit of preload on them when unloaded, right?
I don’t see any shims or spacers under the rocker shaft mounts. I imagine the pushrods are just not the correct match for the lifters and stock rockers.
That video with the Rhodes lifter sounds pretty much like my engine at idle but I kinda don’t think that’s the issue.
Thanks again. Keep the ideas coming.
But rhoads or other fast bleed lifters do just that bleed the pre load off right away. If you rev it up and ticking goes away that's the way they work. If it continues and even gets louder look to pre load problem.
Re: 440 sounds clattery [Re: Dodgem] #679944
04/26/10 02:25 PM
04/26/10 02:25 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Here is a video of the engine idling if anyone is interested in having a listen. It's not quite as apparent in the video as in person.
At the suggestion of the builder, I am going to order a set of .60 longer pushrods to see if that does the trick, also getting an adjustible pushrod tool if the longer rods don't do the trick.
440 Idle
Thankas again all!!
Re: 440 sounds clattery [Re: HitIt] #679945
04/26/10 03:35 PM
04/26/10 03:35 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Is the factory RB pushrod 9.310" ?
