Re: Gauge test
[Re: GKMOPAR]
#678784
04/24/10 11:27 AM
04/24/10 11:27 AM
RapidRobert
I think I'm missing something but take both wires off of the gauge terminals and check each gauge post to ground which would check the gauge body itself for a dead short (dont want continuity as in zero ohms to ground)
Re: Gauge test
[Re: RapidRobert]
#678785
04/24/10 11:48 AM
04/24/10 11:48 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
if you are sure the cluster voltage limiter is in working order, you simply can keep it conected to gauge and ground the other post. No matter wich one goes where as far gets a positive constant source from limiter and the ground ( even for facility they are usually labeled ) what is the colored wire coming from sender.
Ofr course test with key in RUN
if you are unsure about voltage limiter conditionds a 9 volts batt will work to make a test using + and - to both posts, but just hold it for around two seconds to check for needle movement. They are designed to get 5 volts.
