Post deleted by moparts
#678476
04/23/10 08:06 PM
04/23/10 08:06 PM
Re: Cam timing ???
#678478
04/23/10 08:11 PM
04/23/10 08:11 PM
RapidRobert
w them @12 o'clock and 12 o clock w the marks @10BTDC #1 compression you are ready to place the rotor under the dist cap w the #1 wire in it. But it's easier to use a steel scale w the crank dot at 12 because the bolt is in the way the other way so set em at 12 and 6 and at 10 btdc on the marks #6 is ready to fire
[Re: hemigod426]
#678480
04/23/10 08:15 PM
04/23/10 08:15 PM
[Re: buildanother]
#678482
04/23/10 08:29 PM
04/23/10 08:29 PM
Re: Cam timing ???
#678483
04/23/10 08:33 PM
04/23/10 08:33 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
The worst that could happen is a distributor that is 180 degrees out. At the chev dealer, the service writers would transfer calls back to my phone from hotheads that bought a target eng from our dealer the week before, and it just backfires trying to start. They would convince me that the factory installed balancer was on tdc on timing cover when it came out of crate, so it must be firing #1. THey were mistaken, I had to explain to them that the factory lined up the dots, threw a paint mark on them and were done. And that meant it was firing #6 in that position.
[Re: hemigod426]
#678485
04/23/10 08:50 PM
04/23/10 08:50 PM
