just a spark plug question #678333
04/23/10 03:32 PM
04/23/10 03:32 PM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
i run auto lites 85 in my 70 runner 440,factory heads,went to change plugs and for the heck of it i thought i would try champions(don't remeber that number)but the champions seem that they protrude deeper then the auto lites(hope this makes sense)why is that? and i just ended up putting new auto lites instead,something told me not to go with the champs,thoughts?not looking for a who's a better plug. thanks
Re: just a spark plug question [Re: meepmeep70] #678334
04/23/10 04:22 PM
04/23/10 04:22 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
All i ever used in BB mopars was number 85 autolites. Never had a problem. I would say those champs were wrong number for application
Re: just a spark plug question [Re: Dougsmopars] #678335
04/23/10 04:37 PM
04/23/10 04:37 PM
Not a direct ans but you want the reach to be correct so there's no plug nor head threads not being used and therefore exposed to combustion which will create a hot spot and preignition. I'd make sure the champs have the same reach (3/4" iirc but not sure) as the autolite 85's that are known correct. EDIT make sure your choice is not tapered ones if the seat isn't tapered to match
Re: just a spark plug question [Re: RapidRobert] #678336
04/23/10 04:52 PM
04/23/10 04:52 PM
weymouth,mass.
weymouth,mass.
thanks guys,i like the auto lites and will stick with them
