Detonation questions - 440 #677807
04/22/10 11:27 PM
04/22/10 11:27 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Ive been playing with the distributor in my 440 for the last two days. I did get the car to pick up alot below 3500 rpm but heres my problem. The distributor is a stock 1966 440 single point unit.
The advance plate is stamped 8, so it has 16 degrees of total mechanical advance. First off this seems extremely low for a stock dizzy. I know alot of people would like this instead of having to weld up their slots, but I would have to run 22 degrees of initial to get to 38, I think the starter would kick back against that.
It doesnt matter anyway because anything more than 13 degrees of initial pings. Thats only 29 total. It is a stock 68 440 with headers and 2.94 gears and it is the 350 horse engine. Is it possible that cylinder compression could be that high with this cam that I can only run 29 degrees of total timing? This is with Sunoco 93 octane.
Also, I occasionally get a weird sound that sounds like the sound of a hot exhaust pinging after you shut the car off. Its not the marble/rattle sound of detonation, but it is a weird sound and seems to happen more on hills, but the amount of gas you gives it doesnt effect it and its not consistent, it will do it once, then maybe ten seconds later, then stop. Is this anything to worry about?
Re: Detonation questions - 440 [Re: GTX MATT] #677808
04/22/10 11:51 PM
04/22/10 11:51 PM
(1) Stock oe AVS? (2) is your heat riser sending heat up/across the intake? (3) how hot is the eng running? (1) convert to afb/eddy 2 step rods/jets. Check what size of rods/jets your AVs has then get an eddy strip kit w similar size rods/jets in it and epoxy the domed rod caps to make them flat then slightly richen the "cruise" step of the rods. (2) block the heat riser off at the ex manifold flapper valve and install a blocked valley pan metal gasket (3) how hot. EDIT and use 2 step jets from the kit the same or very close to your current size. MORE EDIT swap those 2.94's for some 3.55's especially if you have 15" tires
Re: Detonation questions - 440 [Re: RapidRobert] #677809
04/23/10 12:47 AM
04/23/10 12:47 AM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
If the dizzy is old it could be wore out. The shaft sometimes walks around causing odd firing.Grab the rotor and check side play of the shaft.
I always switch to electronic anymore myself.Points are a pain.
Re: Detonation questions - 440 [Re: RapidRobert] #677810
04/23/10 01:24 AM
04/23/10 01:24 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Yes it is the heat riser is operating, it will be blocked soon as im switching to a Summit 224/234 cam (which will ease the issues for sure) and swapping the intake and blocking the heat riser. It runs at 185 on the nose and does not change.
The carb is an OOTB Holley 770, I haven't played with that yet because I figured I'd be wasting my time since that cam will be changed within a month. I've heard these run lean on the secondaries but My plugs are slightly carboned with a golden brown underneath and a little bit of oil around the outside (not on the groundstrap). It could just be that it runs on the primaries and idles so often and that those are setup a little on the rich side. It does burn some oil, about a quart in 1000 miles.
I have 225/70/15s and a 3.55 sure grip is in the waiting to swap in, but im waiting as im converting to 11 in brakes and want to do it at the same time since I have to pull the axles for both. I have to buy the drums still.
Re: Detonation questions - 440 [Re: GTX MATT] #677811
04/23/10 06:44 AM
04/23/10 06:44 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Could be sucking oil into the chambers. I had a ping at higher RPM and changed the secondary spring to the purple one, ping was gone.
Re: Detonation questions - 440 [Re: GTX MATT] #677812
04/23/10 08:48 AM
04/23/10 08:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You should be able to run about 38* total at 2500 w/ that set-up. Are you sure your distrib is ok? I'm guessing you have switched over to Electronic? If you back the timing down is it a pig? I usually set the timing at 36-38* total and lock it down. Don't forget to unplug the vac advance. I don't worry about initial. Then I adjust the carb for best vacuum reading, set the idle speed and go for a rhomp. FWIW I had the exact set-up (224/234-465/488 cam) in my otherwise bone stock 67 GTX w/ 3.55's and the thing ran 13.80's (14.20's before cam swap) you'll like it once you get it all sorted out.
Coming soon!!!!
Re: Detonation questions - 440 [Re: GTX MATT] #677813
04/23/10 08:49 AM
04/23/10 08:49 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'll bet the distributor bushing is worn right out and wobbling around like an old drunk and your point gap changing from 0 to .045??
Hope the vacuum advance is unhooked for intial tune then on ported vacuum later.
Re: Detonation questions - 440 [Re: Dodgem] #677814
04/23/10 07:13 PM
04/23/10 07:13 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Vacuum is disconnected. I wouldnt call it a pig, but it doesn't run like a 440 should. What play should I look for in the distributor? Up and down or??
Re: Detonation questions - 440 [Re: GTX MATT] #677815
04/23/10 07:41 PM
04/23/10 07:41 PM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
Not up and down. Side to side movement of the shaft.
Re: Detonation questions - 440 [Re: v10] #677816
04/23/10 07:48 PM
04/23/10 07:48 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Alright that makes more sense. How much play would be acceptable?
Re: Detonation questions - 440 [Re: GTX MATT] #677817
04/23/10 07:51 PM
04/23/10 07:51 PM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
No movement to very little. It sounds like yours is very worn out and will move a lot.
Re: Detonation questions - 440 [Re: v10] #677818
04/23/10 07:54 PM
04/23/10 07:54 PM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
Remember any movement will change your points gap.
So very little.
Re: Detonation questions - 440 [Re: GTX MATT] #677819
04/23/10 08:17 PM
04/23/10 08:17 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
All of the suggestions so far are good ones. I have three questions; 1. How long have you owned the car. 2. When did this start? and 3. What changed?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Detonation questions - 440 [Re: GTX MATT] #677820
04/23/10 08:21 PM
04/23/10 08:21 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..'69 shop manual shows initial timing at 5 btdc.
for a total of 35 that would mean mechanical must be 15 x 2 + 5 for 35 tot. w/0 vac advance
at 13 initial + 30, tot would be 43,add vac advance..and it should ping
your distributor must be marked wrong.
Re: Detonation questions - 440 [Re: can.al] #677821
04/24/10 11:58 PM
04/24/10 11:58 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
The slots are VERY short, it is correct when I checked the total it cam up with 16 over the initial.
I checked for play today. It has over 10 thousanths easily, probably closer to 15 thou, so its REALLY bad. Im amazed the thing runs so good since its probably missing spark half the time. NEVER backfires or pops though. I guess my electronic dizzy is going in.
Re: Detonation questions - 440 [Re: GTX MATT] #677822
04/25/10 12:53 AM
04/25/10 12:53 AM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
I think you will be pleasantly pleased with the difference.
Re: Detonation questions - 440 [Re: v10] #677823
04/25/10 12:57 AM
04/25/10 12:57 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I hope so because I can say one thing it DOES NOT run like a 440 should. This is why I've dived into this tuning. To be honest, it feels like a 383 4 barrel, non HP car. Very flat and low on torque with no upper end pull either.
I raced a buddies Road Runner who bought his car with the engine already rebuilt by Jasper engines of all places. It does have good cranking compression and runs great but its low on power, its definately got under 9:1 compression and a non HP cam in it, probably some 400 emissions era replacement. He has 3.23 gears with 28 inch tires, I have 2.94s with 27 inch tires. We were dead even from 30 to 70 and I should have been able to pull away.
Re: Detonation questions - 440 [Re: GTX MATT] #677824
04/25/10 01:25 AM
04/25/10 01:25 AM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
As the shaft moves around it would change your points gap and your timing (causing your ping)
Let us know how things work after the change.
