Isky cam questions #677654
04/22/10 09:20 PM
04/22/10 09:20 PM
melbourne australia
rtandy Offline OP
rtandy  Offline OP
melbourne australia
Hi, apologies for the long winded post. I have just fitted the an old Isky 505 solid cam shaft, lifters and adjustable rockers from my 383 to my 440 (changed push-rods for 440 ones) the problem I have is that when I adjust the rockers on to the push-rods, I do not have enough thread left to fit the lock nuts. I have fitted the lock-nuts to the underside of the rocker arms and although the surface is rough cast, nuts are making contact all the way around. I work for a Cat dealer and have checked with the mechanics there and they all see no reason why I can't do this. My questions are will this be OK or should I try and find longer push-rods (not much available in Aus) also what are the valve lash clearances? Any advice would be much appreciated.
Re: Isky cam questions [Re: rtandy] #677655
04/22/10 09:32 PM
04/22/10 09:32 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Your gonna need longer pushrods.. FWIW different brand lifter bodies can be different lengths & back in the 70's & 80's Isky lifters were about .180 shorter than most, they sold longer pushrods to make up the difference..
Re: Isky cam questions [Re: 1_WILD_RT] #677656
04/22/10 09:41 PM
04/22/10 09:41 PM
melbourne australia
rtandy Offline OP
rtandy  Offline OP
melbourne australia
Thanks 1 Wild, just my luck. I was hoping to fire it up this weekend.
Re: Isky cam questions [Re: rtandy] #677657
04/22/10 09:57 PM
04/22/10 09:57 PM
melbourne australia
rtandy Offline OP
rtandy  Offline OP
melbourne australia
Can anyone help with the clearances? I have been told 0 lash but I am sus on this as every motor I have ever worked on has some lash.
Re: Isky cam questions [Re: rtandy] #677658
04/22/10 10:00 PM
04/22/10 10:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
BTW The .180 number is off old & foggy memory, I highly recomend measuring so you get the correct pushrods without any mistakes..
Re: Isky cam questions [Re: rtandy] #677659
04/22/10 10:02 PM
04/22/10 10:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Zero lash is for hydralic cams, this is a solid, it needs lash..
Re: Isky cam questions [Re: rtandy] #677660
04/22/10 10:07 PM
04/22/10 10:07 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
If you want to chase up longer push rods...you might check with Speedworks in Ringwood and see if he can source anything ?
Re: Isky cam questions [Re: 1_WILD_RT] #677661
04/22/10 10:08 PM
04/22/10 10:08 PM
melbourne australia
rtandy Offline OP
rtandy  Offline OP
melbourne australia
Thanks again 1 Wild, far too many Cheby guys at work. I should have known better than to listen to them lol.
