best inexpensive roller rockers for big block #676501
04/21/10 12:10 PM
04/21/10 12:10 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
so how are the roller rocker setups out there now holding up? who makes the best setup for the lowest $$$ dan
Re: best inexpensive roller rockers for big block [Re: ph23vo] #676502
04/21/10 12:14 PM
04/21/10 12:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Read too many horror stories about the cheapie rockers with their needle bearings. Stay away from rollers unless you absoloutely need them, ductile iron rockers will do a decent cam. How much cam did you really want to run?
Re: best inexpensive roller rockers for big block [Re: ph23vo] #676503
04/21/10 12:17 PM
04/21/10 12:17 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Unless you are running a big cam with lots of spring pressure you will gain nothing with rollers.
Re: best inexpensive roller rockers for big block [Re: ph23vo] #676504
04/21/10 12:19 PM
04/21/10 12:19 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I'm using Crane Gold rollers on my 440 with a 292/.509 Comp cam. The only problem I had was, I used the slightly wrong length pushrods and the cup of the pushrod dug out the rocker around the adjuster on 2 rockers. It ended up looseing the lock nut off the adjuster and I had some running issues.... Got 2 new rockers from Crane, the correct length pushrods (you want about 3-4 threads of the adjuster past the bottom of the rocker), double nutted the adjusters, been perfect since. I think they cost right around $350 from Summit. Hope that helps
Re: best inexpensive roller rockers for big block [Re: JoesMopar] #676505
04/21/10 01:10 PM
04/21/10 01:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'd rather run "good" iron rockers than "cheap" rollers. I prefer the Isky's with the hardened tip inserts but I guess the Crane's are ok too.
Apart from poor construction (materials), just about every roller rocker on the market lacks the ability to spray oil on either the pushrod, springs or both. Even my top dollar Harland Sharp's only oil the pushrod.
The iron Isky's and the Crane's (both appear to have come out of the same mold) oil both the pushrod and the spring.
Re: best inexpensive roller rockers for big block [Re: ph23vo] #676506
04/22/10 09:34 PM
04/22/10 09:34 PM
NE MISSOURI
P
Purpleracer Offline
Purpleracer  Offline
P
NE MISSOURI
I made the mistake of buying a set of CAT rockers when they first came out. One of the adjuster broke while tighten it up. Put them on the self and never used them. They are junk.
Re: best inexpensive roller rockers for big block [Re: ph23vo] #676507
04/22/10 10:22 PM
04/22/10 10:22 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Another vote for iron rockers I have Isky's on my car bushed from R.A.S. and the good shafts they offer too.Pretty much a bullet proof valve train with the Hughes billet holdowns and stud kit.
Gus
64 Plymouth Savoy
Dana 60
