3.09 first gear set better for drag racing? #676263
04/20/10 10:31 PM
04/20/10 10:31 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey guys,
ive heard some say that with the 4 speeds the 3.09 gearset is better for drag racing. I can understand where this generalization comes from since the tall first gear will help the overall first gear ratio and therefore decrease the chances of bogging. However, my concern is the drop in rpm when shifting from 1-2 as i noticed that the second gear ratio is the same as regular 2.66 boxes (i think around 1.91...in the od boxes the second is 1.71 i believe)....Is this drop enough to warrant not running this setup? I dont have a 3.09 gearset right now, but im wonderinf if they are worth picking up since id really like to have more first gear for launch without having to swap a more unfriendly rear end gear ( i have 3.91's right now)
thanks!
Matthew
Re: 3.09 first gear set better for drag racing? [Re: mshred] #676264
04/20/10 11:22 PM
04/20/10 11:22 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
IF you have a good rear suspension and the car hooks ... it could work great.
But if either aspect is not up-to-snuff .. you will blow-the-tires off the car.
Re: 3.09 first gear set better for drag racing? [Re: mshred] #676265
04/20/10 11:29 PM
04/20/10 11:29 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Absolutely depends on the combination. May work well for heavy car/low to medium HP and not at all for a light/medium weight upper HP car.
Re: 3.09 first gear set better for drag racing? [Re: BobR] #676266
04/20/10 11:32 PM
04/20/10 11:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its all about torque.... if you need it... its great
but it also needs to be put to the track
Re: 3.09 first gear set better for drag racing? [Re: MR_P_BODY] #676267
04/21/10 12:56 AM
04/21/10 12:56 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Sounds like a street car? Unfriendly gear? So you got an engine that has a big tq and High HP? I see regular geared 4 speeds doing anything from 1.18 60ft to 1.40 60ft with no problems. A dyno will dictate where your engine runs best. Get under and above those numbers and you will finishing last all the time. Sounds like a lot of trouble to jump out a little to slow down in the middle and then not enough pull room left on the top end. A gear and tire swap is easier
Re: 3.09 first gear set better for drag racing? [Re: mshred] #676268
04/21/10 02:21 AM
04/21/10 02:21 AM
I have used the 3:09 box in a drag car years ago, there is almost no wind restitance or drag on the 1-2 gear change so the car never saw the problem your thinking of. One of the most common aftermarket custom gear ratio for the NP833 had a 2:98 first gear ratio back in the day berfore all of the aftermarket drag race only transmissions came out in the mid 1970s, not far from the stock A body 3.09 ratio. The one bad thing about the 3.09 boxes is the size of the gear on the input shaft Not the strongest rascal availble
Post deleted by Defbob [Re: Cab_Burge] #676269
04/21/10 03:28 AM
04/21/10 03:28 AM
Re: 3.09 first gear set better for drag racing? #676270
04/21/10 06:54 AM
04/21/10 06:54 AM
Netherlands
72Challenger Offline
Netherlands
only old guys know that info
So you should be able to confirm this info
Re: 3.09 first gear set better for drag racing? [Re: Cab_Burge] #676271
04/21/10 09:01 AM
04/21/10 09:01 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
This is good info to know! Ive never seen the 3.09 first, but is it that bad? this will be going into a mid 11 second car, 23 spline tranny if it happens...whatdya think? am i better off just leaving it? i tried calling liberty to see if they had any red stripes left, but getting one of them on the phone is like waiting for the president
most people think that the bigger first gear means blowing tires off, but if you look at all top manual transmision boxes their first ratio is usually a 2.95 or higher, so what explains that? not to mention the t5 i have in the car now is a 3.35 first and TONS of mustang guys hook with t5's and gear ratios lower than mine (4.10's, 4.30, etc.)...Im not disagreeing in the sense that yes the car needs to be able to hook suspension and tire wise, but the tall first gear is almost a must in stick drag racing to stay away from bogging and getting better 60' times...i was more worried about the shift from 1-2 since it seems like quite a drop and im not sure if it will hamper performance or not
Re: 3.09 first gear set better for drag racing? [Re: mshred] #676272
04/21/10 09:54 AM
04/21/10 09:54 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Don't do it. My dad used one for a while and it was slightly better getting out of the hole, but then it ripped the teeth off the gear. Heavy (3900lbs) B body running mid 11's.
First time he tried it, noticed a while later, that the splines were twisted. Didn't break anything, just took the trans out to check everything. So he put in another inputshaft. That one twisted and then ripped all the teeth off.
Maybe the metal that it's made of, is not that strong?
First and ONLY time in 40+years my dad hurt an 833!
Now he's back to stock 23 splint 2.66 ratio stuff,...not hurting a thing.
Oh yeah, slicks, power shifting, letting the tires spin a few revolutions coming out of the hole with a CF dual friction disk.
Post deleted by Defbob [Re: 72Challenger] #676273
04/21/10 10:24 AM
04/21/10 10:24 AM
Re: 3.09 first gear set better for drag racing? #676274
04/21/10 10:42 AM
04/21/10 10:42 AM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
...are you kidding I wrote the book
chiseled in stone...
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: 3.09 first gear set better for drag racing? [Re: mshred] #676275
04/21/10 10:47 AM
04/21/10 10:47 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
stock red stripe ratios vs 309 gear set.
race red stripe--- 2.65 1.64 1.19 1.00
309 gear set----- 3.09 1.92 1.40 1.00
The drop between 3rd and 4th is more of a concern than anything else, and for anything but full race application, that 309 set is a decent affordable option imo.
With todays slipper clutches, longevity should only be improved.
As stated by others, it depends on the package.
Dumping the clutch in anything weighing near 4000 lbs should be expected to have reduced life.
Add bite, hp and no clutch slippage and something will give.
Re: 3.09 first gear set better for drag racing? [Re: BBLM23] #676276
04/21/10 10:49 AM
04/21/10 10:49 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
I was thinking of Moses myself.
Re: 3.09 first gear set better for drag racing? [Re: theclutcher] #676277
04/22/10 10:50 PM
04/22/10 10:50 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
thanks for the info! i had always thought that the redstripe was a 2.95 first, but i guess i was wrong. Its all in the clutch in getting a stickshift to live, so thats definatly something im not gonna skimp on. As far as the 3-4 shift goes, the drop doesnt seem too bad....what kinda car and et's were you seeing with this gearset when you were using it?
Re: 3.09 first gear set better for drag racing? [Re: mshred] #676278
04/24/10 09:24 AM
04/24/10 09:24 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Ran 2.93 liberty box behind 8.5-1 .500 lift 340.
1050 dom. 5.38 dana/14x32's. 11.60et 114-115 mph.
3200lb f body.
run 309 gear set on street in RB 68 cuda.
