Power Steering Pump #675939
04/20/10 07:44 PM
04/20/10 07:44 PM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
In the process of installing a saginaw power steering pump on a '72 R-runner and was wondering about the 2 bolt holes in the rear, all the cars I looked at have studs instead of just bolts to mount rear bracket. Can I just use regular bolts and do the need teflon to prevent leaks? Thanks for any advise!!!
Re: Power Steering Pump [Re: indytex96] #675940
04/20/10 09:36 PM
04/20/10 09:36 PM
NJ
440challenger Offline
NJ
Sb or BB? on Sb i use permatex thread sealent on the botls that go through the Tchain cover
Re: Power Steering Pump [Re: 440challenger] #675941
04/20/10 09:48 PM
04/20/10 09:48 PM
SE Kansas
I
I
SE Kansas
Big Block, what I am asking is the bolts that run into the back of the pump, not the ones that go into the motor.
Re: Power Steering Pump [Re: indytex96] #675942
04/20/10 09:55 PM
04/20/10 09:55 PM
NJ
NJ
hmm.... not sure if i ever put anything on those... im sure someone has done this recently and will post...
Re: Power Steering Pump [Re: 440challenger] #675943
04/20/10 10:02 PM
04/20/10 10:02 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
I've also only ever seen studs. Sorry. I guess bolts would work, but they won't allow you to take the rear bracket off without draining the pump, which is the original intent of using studs in the first place.
