Rim Blow switch install. #674224
04/18/10 10:21 PM
04/18/10 10:21 PM
Roseville,Michigan
GoManGoRT/SE Offline OP
Roseville,Michigan
Anybody ever install a new rimblow horn switch? I've got ?'s. Not sure how the metal ends connect correctly to the wire.
Re: Rim Blow switch install. [Re: GoManGoRT/SE] #674225
04/18/10 10:49 PM
04/18/10 10:49 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Got a picture?
Which part are you talking about?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Rim Blow switch install. [Re: HealthServices] #674226
04/19/10 01:46 AM
04/19/10 01:46 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: Rim Blow switch install. [Re: GoManGoRT/SE] #674227
04/24/10 12:41 PM
04/24/10 12:41 PM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
I've installed hundreds of them and sold quite a few to DIYers. Several years ago we made a detailed procedure with pictures on how to properly install a new rimblow switch. It's too big to attach here but I can send it to you in an email if you want.
Proper connections would be the left side should have the bottom copper strip touching the spoke. The right side should have the top copper strip soldered to the pigtail wire. See attachment.
