Electric fuel pump wiring? #674044
04/18/10 08:56 PM
04/18/10 08:56 PM
Suffolk,VA
I
ireland383 Offline OP
I
Suffolk,VA
Can you run the pump to the accessory terminal at the fuse panel with an inline fuse?
Re: Electric fuel pump wiring? [Re: ireland383] #674045
04/18/10 09:13 PM
04/18/10 09:13 PM
yes and I'd suggest add an on/off switch in the dash between the acc fuse and the tank to give you manual control over it
Re: Electric fuel pump wiring? [Re: RapidRobert] #674046
04/18/10 09:29 PM
04/18/10 09:29 PM
Suffolk,VA
I
I
Suffolk,VA
Yes I will run a toggle. Thanks
Re: Electric fuel pump wiring? [Re: ireland383] #674047
04/18/10 09:33 PM
04/18/10 09:33 PM
IN
ahy Offline
ahy  Offline
IN
Are you running the pump on a relay? If it has a significant current draw, use the acc terminal to power the relay and take the main power from a battery source (solenoid, or battery). Kits are available with the relay and circuit breaker and instructions (painless, summit, Aeromotive ect.) or you can piece it together yourself.
Re: Electric fuel pump wiring? [Re: ahy] #674048
04/18/10 09:37 PM
04/18/10 09:37 PM
Suffolk,VA
I
I
Suffolk,VA
I don't have a relay. The pump draws less than 4amps at full load. Is that too much without a relay?
Re: Electric fuel pump wiring? [Re: ireland383] #674049
04/18/10 10:30 PM
04/18/10 10:30 PM
Shoreline, Washington
72roadrunnergtx Offline
Do yourself a favor and run a relay.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Electric fuel pump wiring? [Re: ireland383] #674050
04/18/10 10:52 PM
04/18/10 10:52 PM
IN
ahy Offline
ahy  Offline
IN
At 4 amps, a relay isn't necessary. It would keep the load off the OE harness which is still a benefit.
