HEMI HOOD SCOOP #674010
04/18/10 08:13 PM
04/18/10 08:13 PM
Northern Indiana, U.S.
senior60 Offline OP
senior60  Offline OP
Are there certain measurements for cutting out a hood for a Hemi scoop on a Dart. Other do you fly by the seat of your pants. Thanks
Re: HEMI HOOD SCOOP [Re: senior60] #674011
04/18/10 08:19 PM
04/18/10 08:19 PM
NJ
440challenger Offline
NJ
i just cut out a 14" hole on top of the air cleaner
Re: HEMI HOOD SCOOP [Re: 440challenger] #674012
04/18/10 08:42 PM
04/18/10 08:42 PM
scratchnfotraction Offline
i cut a hole 2" smaller than the hemi scoop on my truck hood
on my dart the tri-angle middle part of the under side braceing was about the right size for the scoop and left the braceing uncut
a hole as big as the air clearner will work
i went with the full size hole to help remove heat from under the hood and out the bottom
Re: HEMI HOOD SCOOP [Re: 440challenger] #674013
04/18/10 08:43 PM
04/18/10 08:43 PM
Northern New Jersey
EV2AAR Offline
EV2AAR  Offline
Northern New Jersey
Wait until you get the scoop , use it as a template then final trim for the air cleaner.
