I think it has nothing to do with fuel butt when I filled the truck up yesterday then started it to drive it started missing intermittently then would run fine and sometimes it just runs fine and for no reason will just die like you turned off the ignition. I have a superchip programmer to pull codes and they are showing #2-4-6 and sometimes 8 injecter circuit code . also it shows same cylinder misfireing. I have checked the wireing real close for rodent chewing as this happened before to the throttle pos sensor about 3 years ago butno sign of rodents this time. where do I look next?
