main bearing clearance on big block #673655
04/18/10 10:45 AM
04/18/10 10:45 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
When setting the main bearing clearance's on a 500-512" stroker is it tipical to set rear main .001" more clearance that the rest? for instance if i set mains at .003" would the rear have to be .004"? what do you guys like to see for bearing clearance's?
Re: main bearing clearance on big block [Re: mopar dave] #673656
04/18/10 10:55 AM
04/18/10 10:55 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I use .003 no extra on number 5.
Re: main bearing clearance on big block [Re: supercomp] #673657
04/18/10 01:11 PM
04/18/10 01:11 PM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks
Re: main bearing clearance on big block [Re: mopar dave] #673658
04/18/10 01:14 PM
04/18/10 01:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why would you?
Re: main bearing clearance on big block [Re: Thumperdart] #673659
04/18/10 01:36 PM
04/18/10 01:36 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
How would you?
SRT DEMON ONE SEAT
Re: main bearing clearance on big block [Re: Ron Silva] #673660
04/18/10 10:13 PM
04/18/10 10:13 PM
Mt Morris Michigan
Mt Morris Michigan
i'v noticed that when ever i tear my small blocks down there is always more wear on the rear mains than the rest of the bearings. a local engine builder i know puts .0005-.001" on the rear main of the engines he assembles since it takes most of the torque.
Re: main bearing clearance on big block [Re: mopar dave] #673661
04/18/10 10:27 PM
04/18/10 10:27 PM
I run .003+ main bearing clearances on all of the BB I do, I use Federal Mogul narrow groove truck bearings, especially on wedges that will stay under 8000 RPM I don't think any of the major bearing makers offer BB Mopar main bearing sets with a larger rear main bearing, the rear and the other three non thrust bearings are the same part number now
Re: main bearing clearance on big block [Re: Cab_Burge] #673662
04/19/10 06:00 AM
04/19/10 06:00 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I shoot for .0025-.0035 on the mains, if it falls in that zone I can sleep easy. Dave
