I have a 1970 Challenger with 11" drum brakes. I added a power booster, pivot linkage and master cyl off of a 1970 Cuda. The issue is that the brake pedal does not grab until it is an inch off the floor. I have adjusted all the drums until there is a slight drag. I have bled the master cyl and the wheels several times starting with the right rear, left rear, etc. Do I need to adjust the booster rod to the master cyl? I thought that if the whole assembly came off of a working car that that would not be necessary. I looked in the service manual and did not see a procedure to do this. Any ideas? Gerry.
