bb alum bell in pre 70 b body #671233
04/15/10 11:23 PM
04/15/10 11:23 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
Ive got a 68 Roadrunner, its an auto car Im considering changing to a 4 speed...ive got a 71 alum bb bell, is there any reason this wouldnt work in the earlier car? Im not concerened with clutch dia, as ill run whatever works in the bell. also have a 67 small retainer hemi box, I know ill need to swap out the bearing retainer or get a adapter ring...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: bb alum bell in pre 70 b body [Re: pnypwr] #671234
04/15/10 11:35 PM
04/15/10 11:35 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
As long as you use the 130T wheel it will work just fine.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
