how to get 74 ralley cluster out? #671012
04/15/10 09:23 PM
04/15/10 09:23 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
i started taking the cluster out of my 74 satellite my gas gage is not working i grounded the wire from the sending unit for a sec to see if gas gage would move (used to work till i swapped out the dash harness so i think either the limteder is now bad or the wire came off on the gage so i need to take cluster out the top half is all loose but the bottom it still tight i havent undone the heater/ac controls yet just didnt know if there was some hidden screws holding bottom only (i can pull top out inch or 2)
thanks in advance
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: how to get 74 ralley cluster out? [Re: toplescuda] #671013
04/15/10 09:26 PM
04/15/10 09:26 PM
Orange Park, FL
MRHWS Offline
MRHWS  Offline
Orange Park, FL
There are 2 screws on the bottom of the dash attached to the housing, on either side of the steering column. Also the speedo cable will hold you back.
1973 Charger SE 1974 Charger Rallye 440 Aztec 2008 Charger SRT8
Re: how to get 74 ralley cluster out? [Re: MRHWS] #671014
04/15/10 09:53 PM
04/15/10 09:53 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
your not refering to the nuts holding the column to the dash are you? i have the column droped all the way down
1971 charger
Re: how to get 74 ralley cluster out? [Re: toplescuda] #671015
04/15/10 10:21 PM
04/15/10 10:21 PM
Orange Park, FL
MRHWS Offline
MRHWS  Offline
Orange Park, FL
Where the plastic housing goes around the column(upsidedown U)down under the lowest points, kinda behind the dash, are 2 screws. Lay on the floor and look up.
Re: how to get 74 ralley cluster out? [Re: MRHWS] #671016
04/15/10 10:39 PM
04/15/10 10:39 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
well thanks alot now if you would of told me that bout 3pm today i would been done by now (prob not lol) but i got to lay the blame on someone lol
1971 charger
Re: how to get 74 ralley cluster out? [Re: toplescuda] #671017
04/15/10 10:44 PM
04/15/10 10:44 PM
Orange Park, FL
MRHWS Offline
MRHWS  Offline
Orange Park, FL
Don't feel bad. I pulled mine a couple weeks ago 'cause notning was working and couldn't figure what was holding it in. My back was hurting so I layed down(no front seats) and looked up and said D_ _ N, looky there, more screws. I still have problems though. See my post How can this be.
