68 dart hood hinge pics #670892
04/15/10 08:53 PM
04/15/10 08:53 PM
pennsylvania
hotrodram Offline OP
pennsylvania
bought a 68 dart that has fiberglas lift off on it and want to go back to GTS hood. Original hinges are long gone but 2 mounting studs are still present on inner frame. any ideas how original hinge and spring mount up on these 2 studs?.....Thanks! Tom
Re: 68 dart hood hinge pics [Re: hotrodram] #670893
04/15/10 08:57 PM
04/15/10 08:57 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The holes in the hinges slide over the studs and these.....
http://www.restorick.com/proddetail.asp?prod=PushRetainer
are used to hold them into place.
Re: 68 dart hood hinge pics [Re: Neil] #670894
04/15/10 09:06 PM
04/15/10 09:06 PM
pennsylvania
pennsylvania
thanks for info on those. now know how they are held on.....does spring go on top stud or bottom
Re: 68 dart hood hinge pics [Re: hotrodram] #670895
04/15/10 09:18 PM
04/15/10 09:18 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Spring is attached to the hinges and not the car. Each of the two arms that make up the hinge assembly have holes that slide over the studs in the door jamb.
http://cgi.ebay.com/ebaymotors/HOOD-HING...=item5ad8954e57
