Gas Tank Sending Unit leaks #67033
06/03/08 09:00 PM
06/03/08 09:00 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
I have a brand new gas tank,brand new sending unit in a 69 Charger,and it's leaking by the sending unit.Is this a known problem for B body cars? Is there anything I can do to solve this problem? The retainer is tight and the gasket seal is new,and still seaps out,even if the gas tank isn't full.
Re: Gas Tank Sending Unit leaks [Re: tt455] #67034
06/03/08 09:03 PM
06/03/08 09:03 PM
at large
moparphillie Offline
at large
You don't want to hear this, but I would drain the tank, remove the tank, then remove the sending unit and replace the gasket. You must have pinched it when you first installed it. Do not over tighten the retainer ring when you re-install it.
Good luck
Re: Gas Tank Sending Unit leaks [Re: moparphillie] #67035
06/03/08 09:12 PM
06/03/08 09:12 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
hey, my e-body sending unit can wiggle(a little) with the ring tightened all the way.
also the gas gauge likes to hang around 1/2 full...even when full.
are these common ?
Re: Gas Tank Sending Unit leaks [Re: tt455] #67036
06/03/08 09:13 PM
06/03/08 09:13 PM
Ohio
gtxmark Offline
gtxmark  Offline
Ohio
Check to see if the retainer is put on flush to the tank ( I know you probably did this already),or you may have pinched the gasket when installing it. If your using the retainer that came with the tank--throw it away & buy one from a mopar performance dealer. I've had two tanks leak,changed the retainer & zero problems now. If you compare the two retainers, the one that comes with the tank it is slightly THINNER than a mopar performance one. If I remember right I got mine from Mancinni.
Re: Gas Tank Sending Unit leaks [Re: gtxmark] #67037
06/03/08 11:08 PM
06/03/08 11:08 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I used a new mopar seal and the old retainer on my tank. The retainer that came with the tank was too flimsy. Mike
Re: Gas Tank Sending Unit leaks [Re: mopars4ever] #67038
06/03/08 11:52 PM
06/03/08 11:52 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
Thanks Guys,I just placed an order for a new seal and nos retainer.I'll see how that works.
