Power Steering Conversion for a 1970 440 Super Bee 4 s #670260
04/15/10 09:56 AM
04/15/10 09:56 AM
Halifax,Nova Scotia,Canada
Steve Breed Offline OP
A friend of mine has a 1973 parts Challenger.Can I use the power steering parts for my 1970 super bee?I understand that the steering column will not work.Is everthing else useable?
Steve
Re: Power Steering Conversion for a 1970 440 Super Bee 4 s [Re: Steve Breed] #670261
04/20/10 04:21 AM
04/20/10 04:21 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The steering gear unit (Commonly called steering box) will interchange, but you may need to swap over the pitman arm. The pump will work if you use the brackets, hoses and pulleys. There are many combinations of pulleys and brackets over the years, so its best to use a matched set to keep every belt in alignment.
Re: Power Steering Conversion for a 1970 440 Super Bee 4 s [Re: Kern Dog] #670262
04/20/10 04:31 AM
04/20/10 04:31 AM
midwest
I
intragration Offline
I
midwest
I have a '74 'Cuda with a '69 440. I was able to find all the parts necessary through Firm Feel and Year One.
