Re: Steering column harness "warm"
[Re: intragration]
#670127
04/15/10 11:27 AM
04/15/10 11:27 AM
Posts: 4,254 State of Fascism
52savoy
State of Fascism
No ..it's not normal. High resistance causes it and can leed to a meltdown. First, I would check all electrical connections and make sure they are "set". If they are I would check each pin "to ground" with a meter... shouldn't be any reading. If that checks ok, then pull the harness and look for a burnt wire or overheated wire sheathing. If you know what wire it is then disregard checking the wires. But check it to ground, etc,etc. etc.. ps..Another thing that should be done on an old car is pull the bulkhead connectors and look for corrosion. If they are original, they'll have (green)crud in it. I use Pepsi to clean the copper terminals. Pour some in a cup and dip the harness connector in it for about 10 minutes. Rinse off with water,dry and use a spray like WD40 or even white grease.
[Re: intragration]
#670129
04/15/10 08:49 PM
04/15/10 08:49 PM
52savoy
State of Fascism
Sometimes a meter will show grounded. Like the starter circuit when the key is turned to the start position. "High" resistance is bad and "low" is good or better. Not all wires are fused. Some are protected by the fusable link to prevent a meltdown in case of a short and by the time you know, it's too late. A grounded wire and resistance are two different things. Resistance is the how much effort it takes for electrical current to flow.
If it's only with the key turned to "on", it's a matter of isolating it. Look at any circuit that is powered then..like the alternator/harness, heater switch, turn signal, etc...
[Re: 52savoy]
#670130
04/15/10 10:59 PM
04/15/10 10:59 PM
52savoy
State of Fascism
Electrical resistance Voltage can be thought of as the pressure pushing charges along a conductor, while the electrical resistance of a conductor is a measure of how difficult it is to push the charges along. Using the flow analogy, electrical resistance is similar to friction. For water flowing through a pipe, a long narrow pipe provides more resistance to the flow than does a short fat pipe. The same applies for flowing currents: long thin wires provide more resistance than do short thick wires.
The resistance (R) of a material depends on its length, cross-sectional area, and the resistivity (the Greek letter rho), a number that depends on the material.
The resistivity and conductivity are inversely related. Good conductors have low resistivity, while poor conductors (insulators) have resistivities that can be 20 orders of magnitude larger.
Resistance also depends on temperature, usually increasing as the temperature increases. For reasonably small changes in temperature, the change in resistivity, and therefore the change in resistance, is proportional to the temperature change.
At low temperatures some materials, known as superconductors, have no resistance at all. Resistance in wires produces a loss of energy (usually in the form of heat), so materials with no resistance produce no energy loss when currents pass through them.
Ohm's Law In many materials, the voltage and resistance are connected by Ohm's Law:
Ohm's Law : V = IR
