B body trunk floor repair #66999
06/02/08 11:57 PM
06/02/08 11:57 PM
KS
68SportSatvert Offline OP
KS
I need to replace the trunk floor in my 68 Rpot Satellite convertible. The car will not be a show car but a very nice driver. Is the one piece floor worth the extra $$? From what I've seen it's basically twice the price.
Re: B body trunk floor repair [Re: 68SportSatvert] #67000
06/03/08 12:15 AM
06/03/08 12:15 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
If you're a good welder ( My welding isn't that pretty but I can run a grinder pretty good...) and a good body man the sectioned pan would probably work for a driver. With a mat in place they'll never know.
Re: B body trunk floor repair [Re: Silverbullet2] #67001
06/05/08 08:53 PM
06/05/08 08:53 PM
Maine
itali83 Offline
itali83  Offline
Maine
Unless you can magically fit a one piece floor through the trunk opening, go for it, but if you are like the rest of us, do the two piece. The factory put the trunk floor down first and built around it so you can't put a one piece floor through the trunk opening. I used the two piece floor from year one and was happy with the fit, not perfect, but is any aftermarket body panel?
you can see the pics of my trunk floor replacement.
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: B body trunk floor repair [Re: itali83] #67002
06/05/08 09:16 PM
06/05/08 09:16 PM
KS
KS
Thanks!! I'm doing the quarters to so I can get a one piece in. I'm leaning toward teh two piece because of the cost factor.
Re: B body trunk floor repair [Re: 68SportSatvert] #67003
06/05/08 09:25 PM
06/05/08 09:25 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Once you spend the money you will forget it, you will live with a two piece pan forever. You're doing the quarters go with the one piece.
Careful, your character's showing!
Re: B body trunk floor repair [Re: mopar346] #67004
06/05/08 09:29 PM
06/05/08 09:29 PM
central new york
pettyblue440 Offline
central new york
Re: B body trunk floor repair [Re: 68SportSatvert] #67005
06/06/08 01:28 AM
06/06/08 01:28 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Not having to weld the seam will definitely be a plus. I went with the two piece because that's what was available. Once the gas tank and filler tube are in place only a small bit of the seam can be seen from below. I chose to finish mine but I doubt anyone will ever see it to appreciate it.
Re: B body trunk floor repair [Re: 68CoronetRT] #67006
06/06/08 02:35 AM
06/06/08 02:35 AM
People's Republic of Kali
70runner Offline
70runner  Offline
I've done 3 of these 2 piece trunk pans, all on 70B bodies. The gas tank does hide most of the seam and the visible segments can be finished off or, if an undercoated car, coated.
My next 70B involves a quarter replacement so I plan to try the full AMD pan if they ever get any more in.
