What clutch kit would you suggest for an 833. I would like one that could take 550hp/575ft-lbs. I won't be making that amount of power but would like to be able to grow to that point. I was looking at the centerforce dual friction units with the organic/carbon composite disc as well as the mcleod super street pro kits with the organic/ceramic disc. But not 100% sure if those units are up to the job.
The car will be 95% street with a little track time on the test and tune days, plus some street
. Will be using a hydraulic slave cylinder to actuate my stock clutch fork, so a bit harder than stock pedal effort should be okay. Any other suggestions?
