smallblock guys questions about 360 magnum #669458
04/14/10 08:03 AM
04/14/10 08:03 AM
communist bloc of new jersey
jamesc Offline OP
jamesc  Offline OP
haven't messed with smallblock stuff for a long time. what's the stock rocker ratio of the magnum that uses stud mount rockers. also for the factory roller which i "assume" is a steel core? what do they do about the distributor drive? tnx
Re: smallblock guys questions about 360 magnum [Re: jamesc] #669459
04/14/10 09:32 AM
04/14/10 09:32 AM
alabama
belvedere1967 Offline
alabama
rocker ratio is 1.6, and I belive it uses a standard dist drive gear
Re: smallblock guys questions about 360 magnum [Re: belvedere1967] #669460
04/14/10 10:12 AM
04/14/10 10:12 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yup, 1.6 ratio, and stock distributor drive. The biggest difference in the cam is that it has no real provisions on the front for Fuel Pump eccentric. As long as you run an electric pump you'll be fine.
There are some hoaky eccentric conversions for those cams, but I'm not all that fond of them...
Re: smallblock guys questions about 360 magnum [Re: dizuster] #669461
04/14/10 02:01 PM
04/14/10 02:01 PM
jamesc Offline OP
jamesc  Offline OP
sp what's the deal with the cam to drive relationship? afaik you can't run a steel cam core against a cast distributor gear. iirc some manufactures actually put a cast gear on the steel cam core.
Re: smallblock guys questions about 360 magnum [Re: jamesc] #669462
04/14/10 02:28 PM
04/14/10 02:28 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The factory cam as well as MOST aftermarket cams are cast cores,work fine with the factory oil pump drive gear. Billet cores will need a bronze drive gear. The 2pc cores that Crane made are hard to find. Last time I had Comp do me a custom they had a few left,I don't know if they still are.
Re: smallblock guys questions about 360 magnum [Re: goldmember] #669463
04/14/10 04:51 PM
04/14/10 04:51 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
What's your concern? It's not like Magnums don't have a distributor. They use a cast gear just like anyother small block factory cam. Unless it's a billet roller cam, it's no big deal.
Re: smallblock guys questions about 360 magnum [Re: jamesc] #669464
04/14/10 06:48 PM
04/14/10 06:48 PM
AndyF Offline
AndyF  Offline
The distributor gear was a big problem on those motors originally then the gear material was changed and that seemed to solve the problem. From what I was told, the Mopar Peformance gear that you can buy for the SB uses the updated material and there doesn't seem to be an issue anymore.
Re: smallblock guys questions about 360 magnum [Re: dizuster] #669465
04/14/10 08:51 PM
04/14/10 08:51 PM
Bend, Oregon
67cuda340 Offline
super street
67cuda340  Offline
super street
Bend, Oregon
http://www.hughesengines.com/Index/produ...mp;partid=22194
nice piece, have it on mine...
1973 Dodge Dart Sport 360 Drag radials 12.30 1/4 mile 7.82 1/8 mile
Re: smallblock guys questions about 360 magnum [Re: 67cuda340] #669466
04/15/10 11:27 AM
04/15/10 11:27 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah, I know it can be done, but I just don't like the fact that it's only got what... .200" of keyway engagement into the timing gear?
Re: smallblock guys questions about 360 magnum [Re: dizuster] #669467
05/04/10 04:03 PM
05/04/10 04:03 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
The depth of engagement doesn't matter in this case because the key is in shear across its face (.25" x .25", for example), between 2 components mounted side-by-side.
For 2 items fixed to each other by ID/OD, then the length of the key matters as it is in shear across the whole length (.25" x 1" long, for example).
Might not have used 100% accurate description, but the theory stands.
Consider that the camshaft gear uses only a small rollpin to locate it; the clamp force between bolt/washer/camsnout carries the load there. This fuelpump extender is a similar situation.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
