Mad Electrical Start'em up kit?????? #669166
04/13/10 07:53 PM
04/13/10 07:53 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
I have a denso 12v mopar mini starter.Im installing a starter solenoid.Do I use a jumper wire on the starter??? or do I need to install a relay?? any one wire one up?
Re: Mad Electrical Start'em up kit?????? [Re: RATTRAP] #669167
04/13/10 08:13 PM
04/13/10 08:13 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
You just need a jumper between the batt terminal and start terminal. I use copper sheet to make them,then I plate them.I have never purchased "the kit" but made my own since 1981.
Re: Mad Electrical Start'em up kit?????? [Re: goldmember] #669168
04/13/10 08:36 PM
04/13/10 08:36 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
The Kit came with every thing needed, Very complete with nothing left out. Jus what starters u can jumper with a buss bar or wire, What starters do u need a relay switch for??
