Aeromotive Fuel Pressure Issues? LONG
#667358
04/11/10 08:39 PM
04/11/10 08:39 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
I'd swear I'e read about a bunch of pressure related issues to the Aeromotive A1000 Pump in past but of course did some extensive google searches today & could'nt find anything worth reading....
Took my buddies '72 Challenger to track today & spent whole day chasing fuel system around, for second week in row...
Car was just finished last year late, & has a brand new A1000 on it, dual -10 Aeromotive inline filters(one before pump, one after pump), Aeromotive bypass regulator... It's I think off top of my head, -10 feed to reg, -8 bypass return... & we have a -4 gauge line running to an external non isolated 2 5/8 Autometer fuel press gauge on cowl... 16 gallon cell...This was an Aeromotive fuel system "kit" all from Aeromotive...
Put about 45 passes on it last fall, no issues... ran straight 110 Sunoco in it until last day of year @ a test & tune.... he was almost out of 110 & we cut in like 70/30 pump gas. Ran fine, put up new best yada yada...
Over the winter unbeknownst to me, he put a bottle of Sta-bil in the fuel, while his car sat in storage for 5 months...
We took it out first T&T this year, made one pass, air was killer -800 feet below DA, & ran 10.00 @ 136? Previous best was 9.87 @ 137 @ ~+600 DA... Incrementals were hair off, but that was on the old pump gas/110/sta-bil mix.... & had a leaking tube issue in slick & only got one pass. Also trans fluid, gear lube etc were nearly stone cold (36 degree day) So did'nt think much about it...Kind of just attributed it to cold car, cold track (60 sucked), & old fuel etc.
Next week, car still off a little, air was 2100-2400 feet DA all day (felt like August, not April), we started putting fresh 112 in it (all we had, waiting on drum of Q16 to come) & as the fresh 112 got in, car went quicker every pass... I think ended up going 10.08 @ 135.50 @ 2400 DA. So it looked pretty good, but 1/8 MPH was still hair off... then next pass 2100 DA, thing smokes like a diesel... & runs 10.18 @ 134... 104 in 1/8 horrible... Fuel pressure for no reason is now @ 9.5 PSI. We had it set last year @ 7.5 PSI & it had never moved, never varied... never worried about it. Hmm, so I adjusted it, took 4 turns on the adjuster to get it back down to ~7.25-7.5 range???? that's odd.... Made 1 last pass, loses 2nd round.... 10.05 @ 136. All good... MPH in 1/8 "normal" for 2100+ DA etc. Pass looked real clean....
Went back today.... & as he was loading/unloading car, fuel pressure all over place, from 5-9... depending on when you ran pump etc.
1st pass was slow again... like 10.14 @ 134, MPH in 1/8 was off by 2 1/2 MPH looked rich, he said did not check F press... I cleaned out air bleeds, dropped jet couple sizes, F press around 6.0 in pits... 10.08? 136, I put jetting back to 90 SQ where it has been for all year, backed that up with I think a 10.05 & then a 10.02 @ 136. Incrementals all look good now? Ok first pass was a fluke??? DA today was real consistent 1650-1700 all day. So think all is good... 1st round.... 10.12 @ 134, MPH in 1/8 way down... blowing black smoke... Float levels if anything are hair low....& I've adjusted them 3 times in last 2 weeks & really saw no differences in back to back passes, fuel pressure is varying wildy. Now reading low in pits around 4-5... I turn adjuster 1 turn & back to 7...
Buy back in.... 10.10 @ 135 black smoke, gets back to pits & says the F press was 9+ in lanes/burnout & down track... I'm lost. The adjuster is now 3 turns of of where it was last year (3 turns to LOWER pressure) & press as we loaded on trailer was 9.5 PSI...
We are going to drain cell tomorrow night, clean filters & pump, tear reg apart, flush all lines & hope we find something. ???
Hard to bracket race a car that throws out a wild slow pass every once in a while. We run alt on car, & also charge battery between rounds, so bat voltage should not be an issue.... Frustrating day of head scratching....
Re: Aeromotive Fuel Pressure Issues? LONG
[Re: RyanJ]
#667359
04/11/10 08:53 PM
04/11/10 08:53 PM
john from product engineering once told me that if your getting fuel pressure all over the place, its in the needle and seats and not the regulator. start at the carb 1st.
[Re: RyanJ]
#667366
04/12/10 12:01 AM
04/12/10 12:01 AM
Posts: 740 WA
JD Dart
WA
My fuel pressure was all over the place when I first brought out my car last year. What finally fixed the regulator was putting it on shock mounts held steady after that. Also sounds like the Sta-bil is screwing up the regulator and carb. Lets us know if you find anything.
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: RyanJ]
#667368
04/12/10 09:57 AM
04/12/10 09:57 AM
Posts: 16,928 NC
440Jim
NC
I hope he didn't put an entire bottle of Sta-bil in the tank! It only needs an once or two for so many gallons of fuel.
Sounds like a regulator issue, but may be the needle and seats. Take the bowls off and clean in carb cleaner and blow dry. Does that pump have a bypass spring/relief in it also? One of them may be sticking. Good luck figuring out which is the problem. Intermittant stuff can be hard to find, and ruins the entire day. It may be impractical to carry a spare pump and regulator to the track to swap when the problem occurs.
[Re: Challenger 1]
#667370
04/12/10 10:18 AM
04/12/10 10:18 AM
Posts: 19,368 Las Vegas
Al_Alguire
Las Vegas
Is the fuel pressure gauge liquid filled?
As for isolators IMO they are very slow to react so if there is an issue like running out of fuel pressure you wil likely never know.
[Re: 440Jim]
#667371
04/12/10 02:01 PM
04/12/10 02:01 PM
RyanJ
moparts member
moparts member
State College, PA
I'll ask tonight how much Sta-bil he put in, although I doubt he will remember & knowing him, he probably dumped in the whole bottle without even thinking.
The gauge is not a liquid filled one & it is external mount on the cowl, so no isolator needed.
It has the aeromotive inline -10 filters that came with the "kit" before & after the pump, I'll have them apart tonight to see what they are exactly, micron wise.
& I will replace the needles/seats tonight as well, that was something I had'nt thought of, although float level in pits never seems to vary at all.
System worked fine all last year, something just got into it over winter & it now has gremlins....
[Re: RyanJ]
#667375
04/12/10 06:08 PM
04/12/10 06:08 PM
needle and seats are definitely a cause for fuel pressure to rise and be unstable, they are trying seat but if there is any dirt or debris it will make the needles bounce around causing your problems, i'll be curious to see what the problem is ,please keep us updated.
