if your cutting axle,then maybe it could be a problem IMHO
if its not measure correct,you could wind up with side load on the bearing..which they dont like
now,I did run a 489 case 3.55 cone sg with thrust block in for 9 yrs on the street
swaped to a 742 open and I cold chiseld the thrust block out and ran it for a few yrs
I did have 1 bearing go out in the 12 yrs I had them
on the 2nd set with the 742 and no thrust block
IMHO,if it has buttens and you can remove them..I would..it will remove any doubt on the axle cut measurments
I am running the a-body moser axles and asked them about the 489 block,said the axle is set to go with the block in or out
but you have cut yours down some correct??
this would be a good time to PM DrDiff and ask about the thrust block measurements and axle end spaceing..
I think what made my bearing fail was me hauling a empty car dolly 300 miles with it waging back and forth unloaded...that was a annoying ride empty as it wiggled the truck a good amount
couple days later I am on the new greens
I think the side loading back and forth got to the high milage green bearings
good luck
