charging system confussion #666630
04/11/10 01:03 AM
04/11/10 01:03 AM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
Im running a stock alternator and regulator the alt has been rebuilt and the reg is new. my battery is in the trunk and im running a old MP tach drive dist thats electronic and a msd box. this is in my 62 dart. do ineed to switch regs because of the electronic dist or is this set up good .thanks BOB
Re: charging system confussion [Re: moparsquid] #666631
04/11/10 01:21 AM
04/11/10 01:21 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I think the Mopar ECU liked a steady voltage more than an MSD box, but the E-regulator is way ahead -of the points type on voltage "regulation", an inexpensive upgrade.
Re: charging system confussion [Re: pishta] #666632
04/11/10 03:09 AM
04/11/10 03:09 AM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
you can probably get away with what you have, however a new system would provide more consistant voltage. One aspect you need to look at is the wiring itself. Make sure that old wiring is not brittle. Biggest issues with Mopars in my experience is the electrical system. they werent great when new and adding new high voltage components can really stress them. I am sure there is more than one person on this forum that has an electrical horror story.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: charging system confussion [Re: 70chall440] #666633
04/11/10 11:01 AM
04/11/10 11:01 AM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
When I got my A100, the wiring had been butchered to all get out, and I was having major charging issues and killing batteries. I finally said screw it and went to my favorite discount auto store and snagged the alt, V.Reg, and all the wiring that I could get my hands on off of a 74 Dart or something and followed this. http://www.imperialclub.com/Repair/Electrical/charging.htm
All because I couldn't figure what someone else had done with the wiring. It was really simple to do once I figured out what was done with mine. Since then, I'm really happy with the upgraded system. BTW- This upgrade went from a 37 something amp to a 65+ amp alternator. More, yes, but not really streessing the wiring like say using these mega-amp units some guys are using.
Re: charging system confussion [Re: moparsquid] #666634
04/11/10 11:19 AM
04/11/10 11:19 AM
The bottom line is if your batt is being kept properly charged (not under or over). those electromechanical regs are real problematic and you can get an oe appearing one w a black cover for $25 to your door from a member here or your parts house will have a wells vr706 (might be vr607) which is electronic but not stock appearing but your not stock anyway. A suggestion: w batt in trunk I'd use large enough cables and make sure EACH connection is clean w minimal voltage drop.
Re: charging system confussion [Re: 70chall440] #666635
04/11/10 02:49 PM
04/11/10 02:49 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
Thanks I totally agree elecrics is a pain (went crazy on my 73 dat 240z) thats why I swaped it all out for new harness way better, I did after buying two used ones with missing ends. thanks BOB
