clicking noise #666413
04/10/10 08:54 PM
04/10/10 08:54 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
rolling the car into the trailer to go for interior I notice a clicking sound coming from thr tranny. The shifter is not in the car yet but the mech. is and the linkage to the tranny. I think it may just be it is not in neutral all the way and need linkage adjusted. What do you guys think? Thanks
Re: clicking noise [Re: 70 buzz] #666414
04/10/10 09:01 PM
04/10/10 09:01 PM
Parking pawl part way in
Re: clicking noise [Re: RapidRobert] #666415
04/10/10 10:14 PM
04/10/10 10:14 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
four speed car
Re: clicking noise [Re: 70 buzz] #666416
04/10/10 10:33 PM
04/10/10 10:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
U joint.
Re: clicking noise [Re: MoparforLife] #666417
04/11/10 07:04 AM
04/11/10 07:04 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
U joint.
they are new
Re: clicking noise [Re: 70 buzz] #666418
04/11/10 08:15 AM
04/11/10 08:15 AM
Upper Midwest
Upper Midwest
U joint.
they are new
Don't mean that they can't click if installed wrong or a roller gets out of place during installation. That is what it sounds like to me. But I am not there to check it but that is where I would start.
Re: clicking noise [Re: MoparforLife] #666419
04/11/10 09:48 AM
04/11/10 09:48 AM
scratchnfotraction Offline
zip tie around drive shaft
could be the speedo cable,I have had a couple broke/frayed and clicked down by the tranz plug
could be the out put shaft turning and not the input shaft turning
bearing is the 4 speed itself
Re: clicking noise [Re: scratchnfotraction] #666420
04/11/10 01:01 PM
04/11/10 01:01 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Ok, thanks guys I will check both.
