Re: Too much oil pressure
[Re: emarine01]
#666175
04/10/10 05:09 PM
04/10/10 05:09 PM
I had the same thing on my 414 m72hv pump, swapped relief springs from another pump now its 64 cold and 45 hot @ idle and 64 at all rpm over 2000
X 3 BUT LET the motor get hot 1st and see where your psi is at lets say 180 degrees.then play around with the relief spring if the pressure doesnt go down enough. my 65 dodge coronet has about 100 cold but then drops down and stays around 65 all the time hot.
