4 spd trans ID #666058
04/10/10 01:15 PM
04/10/10 01:15 PM
North Pole,New York
formula_s Offline OP
North Pole,New York
Neighbor has a 4 spd ,#'s are C13546b,582980 on the case. On the tailshaft:C9953,553. That case is aluminum and the tailshaft is cast iron. I suspect it is an overdrive trans?
Re: 4 spd trans ID [Re: formula_s] #666059
04/10/10 04:29 PM
04/10/10 04:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Look for the stamped numbers on the raised boss on the passenger side of the main case.
If the front bearing retainer is 5 1/8" in diameter it is an OD trans.
Re: 4 spd trans ID [Re: John_Kunkel] #666060
04/11/10 03:48 PM
04/11/10 03:48 PM
North Pole,New York
North Pole,New York
Numbers from the raised boss are: T833(space)1990.
