Holley ID HELP!!!! #666027
04/10/10 12:56 PM
04/10/10 12:56 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Anyone know what size this Holley carb is? The numbers on the metering blocks are #6497/4777 and #6509/4777. Up near the middle are CN K A4X and on the inside of the ring is 6R3760. Any help would be appreciated! Thanks.
Admiration For Multiple Carburetor Vehicles...
Re: Holley ID HELP!!!! [Re: Stewpar] #666028
04/10/10 01:49 PM
04/10/10 01:49 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well by the metering block numbers it's a 650 double pumper
Re: Holley ID HELP!!!! [Re: Dodgem] #666029
04/10/10 03:14 PM
04/10/10 03:14 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
Dodgem,Do you know what casting numbers on the metering blocks go on which carbs?Because I have mixed up some of the blocks on my carbs.The blocks in question do not have a number like 4777,which I know what those numbers mean.
Re: Holley ID HELP!!!! [Re: 540DUSTER] #666030
04/10/10 03:35 PM
04/10/10 03:35 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
What's it worth? Came off of a running motor and has new gaskets? Thank you.
