Just ordered my oil plate!!! #665381
04/09/10 04:36 PM
04/09/10 04:36 PM
Finally a HUSKER again
Moparnut426 Offline OP
From Canton. i dont need an aluminum one, but I hate oil leaks, and the O rings design seems great. Any one on here running one on a stock mopar small block? How was the fit?
Kasey
Re: Just ordered my oil plate!!! [Re: Moparnut426] #665382
04/09/10 05:25 PM
04/09/10 05:25 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I don't even know what it is ??
Re: Just ordered my oil plate!!! [Re: VernMotor] #665383
04/09/10 06:37 PM
04/09/10 06:37 PM
Ordered a small block Oil Filterplate from Canton. Here is a linky.
http://www.cantonracingproducts.com/cgi-bin/commerce.cgi?search=action&category=2256
Sorry kinda vague for some of you big block guys.
Kasey
Re: Just ordered my oil plate!!! [Re: Moparnut426] #665384
04/09/10 06:48 PM
04/09/10 06:48 PM
Az
Crizila Offline
Crizila  Offline
Az
Cool! Never even knew they made one. My OEM plate, which is new, leaks a little - right on the header of course. Does the filter sit any farther out than with the stock plate?
Fastest 300
Re: Just ordered my oil plate!!! [Re: Crizila] #665385
04/09/10 06:58 PM
04/09/10 06:58 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
OK Oil filter plate..got it..
Re: Just ordered my oil plate!!! [Re: VernMotor] #665386
04/09/10 09:14 PM
04/09/10 09:14 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I have it on a Magnum (R3) block.
Fits good.
Has not run yet so I cannot tell you if it leaks
SRT DEMON ONE SEAT
Re: Just ordered my oil plate!!! [Re: Ron Silva] #665387
04/09/10 09:41 PM
04/09/10 09:41 PM
honestly your build is where I found them. I wasnt happy with my new steel one, it was warped all over, and I hate leaks. I figured an aluminum piece with an O ring should seal pretty damn good.
Kasey
Re: Just ordered my oil plate!!! [Re: Moparnut426] #665388
04/09/10 11:04 PM
04/09/10 11:04 PM
N
NITROUSN Offline
NITROUSN  Offline
N
For the most part a waste of money.
Re: Just ordered my oil plate!!! [Re: NITROUSN] #665389
04/09/10 11:37 PM
04/09/10 11:37 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i've never had a problem sealing them up. i usually just coat the paper gasket with some copper tack or some form a gasket.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Just ordered my oil plate!!! [Re: NITROUSN] #665390
04/09/10 11:53 PM
04/09/10 11:53 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
No.
A waste of money would be ordering one , then digging into the water jacket while relieving the mis-matched drill bit paths in the bottom of the filter inlet bore.
I also have the 5.00 threaded fitting that Canton doesn't supply.
Anyone need them ?
I have the block repaired thanks to Ryan J. and have converted to a remote filter , so this stuff will be a 50.00 paper weight unless I can sell or swap them.
