late model alt #66521
05/31/08 08:50 AM
05/31/08 08:50 AM
Ft Worth,Tx
71mopar383 Offline OP
super street
super street
Ft Worth,Tx
Can the late model 89-96ish alt be regulated internal or do they have to externally regulated?
71 Charger
Re: late model alt [Re: 71mopar383] #66522
05/31/08 02:04 PM
05/31/08 02:04 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I used a toyota 4runner bosh alt. It is internally regulated 60 amp unit on my small block. I made my brackets,but you can by them from Magnum HP. In the tech archive is the part number for the alt and years of the 4 runner. Very happy with the results.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: late model alt [Re: FurryStump] #66523
05/31/08 02:54 PM
05/31/08 02:54 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm running the 60 amp alternator. I like it, and it charges way better at idle than any factory alt I've ever tried. I got it with the brackets from Mancini's. It's internally regulated, but has a 12v sense wire that needs to be connected at either the starter relay or to the battery.
Re: late model alt [Re: FurryStump] #66524
05/31/08 02:54 PM
05/31/08 02:54 PM
Ft Worth,Tx
super street
super street
Ft Worth,Tx
I knew that one was but I didnt know if the mopar one was since it put out more juice
71 Charger
